<!– Class –> Provides editing options when the EditOverlay is in EditShape mode.
*System.Object **ThinkGeo.MapSuite.MvcEdition.EditSettings
EditSettings | Initialize an instance of the EditSetting class. |
IsDraggable | Boolean | Gets a value that indicates whether the shape can be dragged. | |
IsReshapable | Boolean | Gets a value that indicates whether the shape can be reshaped. | |
IsResizable | Boolean | Gets a value that indicates whether the shape can be resized. | |
IsRotatable | Boolean | Gets a value that indicates whether the shape can be rotated. |
Load this object from a json string.
| jsonString | String<!– System.String –> | a json string |
<!– ThinkGeo.MapSuite.MvcEdition.EditSettings –> Go Back
Returns a JSON string that contains the information for setting the edit mode at client side.
| String<!– System.String –> | A JSON string that is used to set the edit mode at client side. |
