<!– Class –> A setting for ContextMenu that contains APIs to set properties of ContextMenu using in MVC view.
*System.Object
* MvcEdition [ThinkGeo.MapSuite.MvcEdition.ContextMenuSetting * PublicKeyToken=null] Culture=neutral * Version=9.0.0.0 MvcEdition *ThinkGeo.MapSuite.MvcEdition.MvcElementSettingBase`2[[ThinkGeo.MapSuite.MvcEdition.ContextMenu ThinkGeo.MapSuite.MvcEdition.ContextMenuSetting
![]() | ContextMenu | Initializes a new instance of the ContextMenuSetting class. |
![]() | String | Set css Class for Element property and retun the ContextMenuSetting | |
![]() | Object | Object | |
![]() | Object | ||
![]() | Object | ||
![]() | String | Set Id for Element property and retun the ContextMenuSetting | |
![]() | Action<ContextMenuItemCollection> | Set Menu Items for Element property according to the input method which takes ContextMenuItemCollection and retun the ContextMenuItemSetting | |
![]() | Object | ||
![]() | Int32 | Set width for Element property and retun the ContextMenuSetting |
![]() | Object | ||
![]() | Object |
![]() | ContextMenu | MvcElementSettingBase<ContextMenu,ContextMenuSetting> |
Name | Type | Description |
contextMenu | ContextMenu<!– ThinkGeo.MapSuite.MvcEdition.ContextMenu –> |
Return Type | Description |
ContextMenuSetting<!– ThinkGeo.MapSuite.MvcEdition.ContextMenuSetting –> | The setting of ContextMenu itself |
cssClass | String<!– System.String –> | A css Class for Element property |
<!– ThinkGeo.MapSuite.MvcEdition.ContextMenuSetting –> Go Back
Int32<!– System.Int32 –> |
Type<!– System.Type –> |
id | String<!– System.String –> | A id for Element property |
ContextMenuSetting<!– ThinkGeo.MapSuite.MvcEdition.ContextMenuSetting –> | The setting of ContextMenuItem itself |
addMenuItemAction | Action<ContextMenuItemCollection><!– System.Action{ThinkGeo.MapSuite.MvcEdition.ContextMenuItemCollection} –> | A method that takes a ContextMenuItemCollection |
width | Int32<!– System.Int32 –> | A width for Element property |
Void<!– System.Void –> |
Return Type |
<!– ThinkGeo.MapSuite.MvcEdition.MvcElementSettingBase{ThinkGeo.MapSuite.MvcEdition.ContextMenu,ThinkGeo.MapSuite.MvcEdition.ContextMenuSetting} –> Go Back
