<!– Class –> This class represents a right-click shortcut menu used in the map control.
The ContextMenu class represents a right-click shortcut menu which displays when a user right-clicks on a map or an element of a map. Shortcut menus are typically used to combine different menu items that are useful for the user, given the context of the application.
Use the <strong>CssClass</strong> property to customize the appearance of the context menu. The <strong>MenuItems</strong> property holds the items in the context menu.
You can set the <strong>Width</strong> of the context menu, and the height of the context menu will be automatically ajusted to fit all of the menu's items.
*System.Object **ThinkGeo.MapSuite.MvcEdition.ContextMenu
ContextMenu | Initializes a new instance of the ContextMenu class with no menu items specified. | ||
ContextMenu | String, Int32 | Initializes a new instance of the ContextMenu class with the specified identifier and width. | |
ContextMenu | String, Int32, String | Initializes a new instance of the ContextMenu class with the identifier, width and CSS class string. |
CloneDeep | Creates a deep copy of this ContextMenu object. | ||
FromJson | String | Load this object from a json string. | |
ToJson | Returns a JSON string that contains information for creating the context menu at the client side. | ||
CssClass | String | Gets or sets the CSS class of the context menu. | |
Id | String | Gets the identifier of the ContextMenu object. | |
MenuItems | GeoKeyedCollection<ContextMenuItem> | Gets the menu item collection of the context menu. | |
Width | Int32 | Gets or sets the width of the context menu. |
Initializes a new instance of the ContextMenu class.
| id | String<!– System.String –> | The key of the context menu in string format. |
| width | Int32<!– System.Int32 –> | The width of the context menu. |
| cssClass | String<!– System.String –> | The CSS class for the context menu. |
| ContextMenu<!– ThinkGeo.MapSuite.MvcEdition.ContextMenu –> | A deep copy of the ContextMenu object. |
<!– ThinkGeo.MapSuite.MvcEdition.ContextMenu –> Go Back
| jsonString | String<!– System.String –> | a json string |
| String<!– System.String –> | A string for creating the context menu at the client side. |
| GeoKeyedCollection<ContextMenuItem><!– ThinkGeo.MapSuite.MvcEdition.GeoKeyedCollection{ThinkGeo.MapSuite.MvcEdition.ContextMenuItem} –> |
