thinkgeo.mapsuite.mvcedition.clustermarkerstylesetting
ThinkGeo.MapSuite.MvcEdition.ClusterMarkerStyleSetting
<!– Class –> A setting for ClusterMarkerStyle that contains APIs to set properties of ClusterMarkerStyleSetting using in MVC view.
*System.Object
  • PublicKeyToken=null]]
    • Culture=neutral
      • Version=9.0.0.0
* MvcEdition [ThinkGeo.MapSuite.MvcEdition.ClusterMarkerStyleSetting * PublicKeyToken=null] Culture=neutral * Version=9.0.0.0 MvcEdition *ThinkGeo.MapSuite.MvcEdition.MvcElementSettingBase`2[[ThinkGeo.MapSuite.MvcEdition.ClusterMarkerStyle PublicKeyToken=null]] * Culture=neutral Version=9.0.0.0 * MvcEdition [ThinkGeo.MapSuite.MvcEdition.ClusterMarkerStyleSetting * PublicKeyToken=null] Culture=neutral * Version=9.0.0.0 MvcEdition *ThinkGeo.MapSuite.MvcEdition.MarkerStyleSetting`2[[ThinkGeo.MapSuite.MvcEdition.ClusterMarkerStyle **ThinkGeo.MapSuite.MvcEdition.ClusterMarkerStyleSetting
Public MethodClusterMarkerStyleSetting ClusterMarkerStyle Initializes a new instance of the ClusterMarkerStyleSetting class.
Public MethodDistanceInPixel Double Set distanceInPixel for Element property and retun the ClusterMarkerStyleSetting
Public MethodGetType Object
Public MethodMapHeight Double Set mapHeight for Element property and retun the ClusterMarkerStyleSetting
Public MethodMapWidth Double Set mapWidth for Element property and retun the ClusterMarkerStyleSetting
Public MethodMarkerStyle Action<MarkerStyleCollection> Set MarkerStyle for Element property according to a method that takes MarkerStyleCollection and retun the ClusterMarkerStyleSetting
Public MethodToString Object
ClusterMarkerStyleSetting(ClusterMarkerStyle)
Name Type Description
style ClusterMarkerStyle<!– ThinkGeo.MapSuite.MvcEdition.ClusterMarkerStyle –> the ClusterMarker Style which will be assigned to Element property
Go Back
DistanceInPixel(Double)
Return Type Description
ClusterMarkerStyleSetting<!– ThinkGeo.MapSuite.MvcEdition.ClusterMarkerStyleSetting –> The setting of ClusterMarkerStyleSetting itself
distanceInPixel Double<!– System.Double –> A distanceInPixel for Element property
<!– ThinkGeo.MapSuite.MvcEdition.ClusterMarkerStyleSetting –> Go Back
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
MapHeight(Double)
mapHeight Double<!– System.Double –> A mapHeight for Element property
MapWidth(Double)
mapWidth Double<!– System.Double –> A mapWidth for Element property
MarkerStyle(Action<MarkerStyleCollection>)
actionMarkerStyle Action<MarkerStyleCollection><!– System.Action{ThinkGeo.MapSuite.MvcEdition.MarkerStyleCollection} –> a method that takes MarkerStyleCollection
String<!– System.String –>
Void<!– System.Void –>
Element
Return Type
<!– ThinkGeo.MapSuite.MvcEdition.MvcElementSettingBase{ThinkGeo.MapSuite.MvcEdition.ClusterMarkerStyle,ThinkGeo.MapSuite.MvcEdition.ClusterMarkerStyleSetting} –> Go Back
thinkgeo.mapsuite.mvcedition.clustermarkerstylesetting.1440040131.txt.gz · Last modified: 2015/09/21 03:32 (external edit)
