thinkgeo.mapsuite.mvcedition.clientcache
ThinkGeo.MapSuite.MvcEdition.ClientCache
<!– Class –> This class controls how the map images are cached by the browser.
The ClientCache class controls whether the map images will be cached by the browser. Setting the <strong>CacheId</strong> will enable the browser to cache the map images.
The <strong>CacheId</strong> string will be appended to the URL of the image. The browser uses the URL as the key to retrieve a cached image. Thus, you can make the browser cache different images by setting the <strong>CacheId</strong> to different values. For example, you can set a different CacheId for requests with different parameters and the browser will cache the different images for those requests.
The <strong>Duration</strong> defines the length of time that the images will remain in the browser cache. After that time, the image will then be requested from the server.
Public MethodClientCache Initializes a new instance of the ClientCache class.
Public MethodClientCache TimeSpan Initializes a new instance of the ClientCache class with the specified expiration time.
Public MethodClientCache TimeSpan, String Initializes a new instance of the ClientCache class with the specified expiration time and cacheId string.
Public MethodFromJson String Load this object from a json string.
Public MethodGetType Object
Public MethodToJson Returns a JSON string containing the CacheId that will be part of the request string.
Public MethodToString Object
Public PropertyCacheId String Gets or sets a string that enables the browser to cache images, and which is also part of the key for the browser to distinguish between each cached image.
Public PropertyDuration TimeSpan Gets or sets the expiration time of the images in the browser cache.
ClientCache()
Overloads
Name Type Description
Go Back
ClientCache(TimeSpan)
Overloads
duration TimeSpan<!– System.TimeSpan –> The amount of the time that the cached images are to remain in the browser cache.
Go Back
ClientCache(TimeSpan, String)
Overloads
cacheId String<!– System.String –> A string that the browser uses to retrieve a cached image.
Go Back
Return Type Description
Boolean<!– System.Boolean –>
FromJson(String)
Void<!– System.Void –>
jsonString String<!– System.String –> a json string
<!– ThinkGeo.MapSuite.MvcEdition.ClientCache –> Go Back
Int32<!– System.Int32 –>
Type<!– System.Type –>
ToJson()
String<!– System.String –> A JSON string that contains the CacheId.
CacheId
Setting the <strong>CacheId</strong> will enable the browser to cache the map images. The <strong>CacheId</strong> string will also be appended to the URL of the image. The browser uses the URL as the key to retrieve a cached image; thus, you can make the browser cache different images by setting the <strong>CacheId</strong> to different values. For example, you can set a different CacheId for requests with different parameters and the browser will cache the different images for those requests.
Return Type
Duration
The <strong>Duration</strong> indicates the length of time that images will remain in the browser cache before expiring. The default value is 7 day.
Return Type
thinkgeo.mapsuite.mvcedition.clientcache.1440040131.txt.gz · Last modified: 2015/09/21 03:32 (external edit)
