thinkgeo.mapsuite.mvcedition.bingmapsoverlaysetting
ThinkGeo.MapSuite.MvcEdition.BingMapsOverlaySetting
<!– Class –> A setting for BingMapsOverlay that contains APIs to set properties of BingMapsOverlaySetting using in MVC view.
*System.Object
  • PublicKeyToken=null]]
    • Culture=neutral
      • Version=9.0.0.0
* MvcEdition [ThinkGeo.MapSuite.MvcEdition.BingMapsOverlaySetting * PublicKeyToken=null] Culture=neutral * Version=9.0.0.0 MvcEdition *ThinkGeo.MapSuite.MvcEdition.MvcElementSettingBase`2[[ThinkGeo.MapSuite.MvcEdition.BingMapsOverlay PublicKeyToken=null]] * Culture=neutral Version=9.0.0.0 * MvcEdition [ThinkGeo.MapSuite.MvcEdition.BingMapsOverlaySetting * PublicKeyToken=null] Culture=neutral * Version=9.0.0.0 MvcEdition *ThinkGeo.MapSuite.MvcEdition.OverlaySetting`2[[ThinkGeo.MapSuite.MvcEdition.BingMapsOverlay **ThinkGeo.MapSuite.MvcEdition.BingMapsOverlaySetting
Public MethodBingMapsOverlaySetting BingMapsOverlay Initializes a new instance of the BingMapsOverlaySetting class.
BingMapsOverlaySetting(BingMapsOverlay)
Name Type Description
bingMapOverlay BingMapsOverlay<!– ThinkGeo.MapSuite.MvcEdition.BingMapsOverlay –>
Go Back
AutoRefreshInterval(TimeSpan)
Return Type Description
BingMapsOverlaySetting<!– ThinkGeo.MapSuite.MvcEdition.BingMapsOverlaySetting –>
timeSpan TimeSpan<!– System.TimeSpan –>
<!– ThinkGeo.MapSuite.MvcEdition.OverlaySetting{ThinkGeo.MapSuite.MvcEdition.BingMapsOverlay,ThinkGeo.MapSuite.MvcEdition.BingMapsOverlaySetting} –> Go Back
Credentials(String)
Set credentials for Element property and retun the BingMapsOverlaySetting
BingMapsOverlaySetting<!– ThinkGeo.MapSuite.MvcEdition.BingMapsOverlaySetting –> The setting of BingMapsOverlaySetting itself
credentials String<!– System.String –> A credentials for Element property
<!– ThinkGeo.MapSuite.MvcEdition.BingMapsOverlaySetting –> Go Back
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
Id(String)
id String<!– System.String –>
IsBaseOverlay(Boolean)
isBaseOverlay Boolean<!– System.Boolean –>
IsVisible(Boolean)
isVisible Boolean<!– System.Boolean –>
IsVisibleInOverlaySwitcher(Boolean)
isVisibleInOverlaySwitcher Boolean<!– System.Boolean –>
MapType(BingMapsStyle)
Set mapType for Element property and retun the BingMapsOverlaySetting
mapType BingMapsStyle<!– ThinkGeo.MapSuite.MvcEdition.BingMapsStyle –> A mapType for Element property
Name(String)
name String<!– System.String –>
OnClientAutoRefreshTick(String)
clientTickFunctionName String<!– System.String –>
Opacity(Single)
opacity Single<!– System.Single –>
Void<!– System.Void –>
Element
Return Type
<!– ThinkGeo.MapSuite.MvcEdition.MvcElementSettingBase{ThinkGeo.MapSuite.MvcEdition.BingMapsOverlay,ThinkGeo.MapSuite.MvcEdition.BingMapsOverlaySetting} –> Go Back
thinkgeo.mapsuite.mvcedition.bingmapsoverlaysetting.1440040131.txt.gz · Last modified: 2015/09/21 03:32 (external edit)
