thinkgeo.mapsuite.mvcedition.bingmapsoverlay
ThinkGeo.MapSuite.MvcEdition.BingMapsOverlay
<!– Class –> Represents an overlay object that gets images from Microsoft's Virtual Earth server.
The VirtualEarthOverlay registers Virtual Earth's Javascript library to the page and gets the map images from the Virtual Earth server. The VirtualEarthOverlay can only be the base overlay of the map, over which other overlays are laid.
Public MethodBingMapsOverlay Initialize an instance of the VirtualEarthOverlay class.
Public MethodBingMapsOverlay String, String Initialize an instance of the BingMapOverlay class with the overlay identifier, bingMaps map type and bingMapsKey.
Public MethodBingMapsOverlay String, String, BingMapsStyle Initialize an instance of the BingMapOverlay class with the overlay identifier, bingMaps map type and bingMapsKey.
Public MethodFromJson String Overlay(overriden) Load this object from a json string.
Public MethodGetType Object
Public MethodToJson Overlay Returns a JSON string which contains the information for creating an overlay at the client side.
Public MethodToString Object
Protected MethodRegisterJavaScriptLibraryCore Page Overlay Registers a Javascript library URL string to the client HTML page.
Public PropertyAttribution String Overlay
Public PropertyAutoRefreshInterval TimeSpan Overlay Gets or sets the time interval in which the MarkerOverlay refreshes itself.
Public PropertyBingMapsKey String
Public PropertyId String Overlay Gets the identifier for the overlay to be found.
Public PropertyIsBaseOverlay Boolean Overlay Gets or sets a value that indicates whether the overlay is a base overlay.
Public PropertyIsVisible Boolean Overlay Gets or sets a value that indicates whether the overlay is visible on the map.
Public PropertyIsVisibleInOverlaySwitcher Boolean Overlay Gets or sets a value that indicates whether the overlay name is displayed in the OverlaySwitcher.
Public PropertyMapStyle BingMapsStyle Gets or sets a value to display which type of Virtual Earth map.
Public PropertyName String Overlay Gets or sets the name of the overlay, which will display in the OverlaySwitcher.
Public PropertyOnClientAutoRefreshTick String Overlay(overriden) Don't support auto tick event by default.
Public PropertyOpacity Single Overlay Gets or sets the opacity level of the overlay.
Protected PropertyOverlayType String Overlay(overriden) Gets a string that indicates the overlay type.
BingMapsOverlay()
Overloads
Name Type Description
Go Back
BingMapsOverlay(String, String)
Overloads
Initialize an instance of the BingMapOverlay class.
id String<!– System.String –> The identifier that will be used to find the overlay.
bingMapsKey String<!– System.String –> the Bing Maps key registered from https://www.bingmapsportal.com/, it will be used to authenticate against any of the REST Services APIs.
Go Back
BingMapsOverlay(String, String, BingMapsStyle)
Overloads
bingMapsMapStyle BingMapsStyle<!– ThinkGeo.MapSuite.MvcEdition.BingMapsStyle –> The Bing Map styles.
Go Back
Return Type Description
Boolean<!– System.Boolean –>
FromJson(String)
Void<!– System.Void –>
jsonString String<!– System.String –> a json string
<!– ThinkGeo.MapSuite.MvcEdition.Overlay(overriden) –> Go Back
Int32<!– System.Int32 –>
Type<!– System.Type –>
ToJson()
String<!– System.String –> A JSON string which is used to create an overlay at the client side.
<!– ThinkGeo.MapSuite.MvcEdition.Overlay –> Go Back
The <strong>RegisterJavaScriptLibraryCore</strong> method allows derived classes to override and register their own Javascript library URL to the HTML page.
page Page<!– System.Web.UI.Page –> The page object that is used for registering the javascript library.
Attribution
Return Type
AutoRefreshInterval
Return Type
TimeSpan<!– System.TimeSpan –>
BingMapsKey
Return Type
<!– ThinkGeo.MapSuite.MvcEdition.BingMapsOverlay –> Go Back
Id
Return Type
IsBaseOverlay
Return Type
IsVisible
Return Type
Return Type
MapStyle
Return Type
Return Type
Return Type
Opacity
The <strong>Opacity</strong> property enables you to specify a level of transparency for the overlay. When this property is set to a value less than 100 percent (1.00), the entire overlay is made more transparent. The lower the value, the more transparent it is. Setting this property to a value of 0 percent (0.00) makes the overlay completely invisible.
Return Type
Single<!– System.Single –>
OverlayType
Return Type
thinkgeo.mapsuite.mvcedition.bingmapsoverlay.1440040131.txt.gz · Last modified: 2015/09/21 03:32 (external edit)
