<!– Class –> (This class is not finally released, it is possible to be removed in the next public release)
*System.Object System.EventArgs *ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPluginGettingMatchingDataFromIndexRangeEventArgs
*StreetMatchingPluginGettingMatchingDataFromIndexRangeEventArgs | |||
*StreetMatchingPluginGettingMatchingDataFromIndexRangeEventArgs | String, String, Int32, Int32 |
*Equals | Object | Object | |
*GetHashCode | Object | ||
*GetType | Object | ||
*ToString | Object |
*Finalize | Object | ||
*MemberwiseClone | Object |
*Count | Int32 | ||
*DBFName | String | ||
*SourceText | String | ||
*StartIndex | Int32 |
| dbfName | String<!– System.String –> | |
| sourceText | String<!– System.String –> | |
| startIndex | Int32<!– System.Int32 –> | |
| count | Int32<!– System.Int32 –> |
<!– ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPluginGettingMatchingDataFromIndexRangeEventArgs –> Go Back
NOTOC Note: * – not public released, might be removed in the next release. MapSuiteGeocoder ThinkGeo.MapSuite.MapSuiteGeocoder UpdateDocumentation
