This class implements soundex matching operations. There are two columns in the DBF file that are necessary for soundex matching. The first is the soundex value generated by certain Soundex algorithms (by default this is implemented by SimplifiedSoundex). The second is the exact value.
AddRecord(IEnumerable<Object>)
SearchUpperBound(Int32,Int32,String,String)
SearchLowerBound(Int32,Int32,String,String)
BinarySearch(Int32,Int32,String,String)
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#SoundexRealValueColumnName
Gets and sets the path and file name of the DBF file to be used for Geocoding.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#PathFileName
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#ReadWriteMode
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#RecordCount
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#RankingMultiplier
