thinkgeo.mapsuite.mapsuitegeocoder.dbfmatchingplugincolumn
ThinkGeo.MapSuite.MapSuiteGeocoder.DbfMatchingPluginColumn
<!– Structure –> This structure represents the DBF column definition.
Public MethodDbfMatchingPluginColumn String, DbfMatchingPluginColumnType, Int32 This is the constructor of this structure.
Public MethodEquals Object Object(overriden) Determines whether the specified Object is equal to the current Object.
Public MethodGetHashCode Object(overriden) Serves as a hash function for DbfMatchingPluginColumn.
Public MethodGetType Object
Public MethodToString Object(overriden) Returns a formatted String that represents the current object.
Public PropertyColumnLength Int32 This property is the column length.
Public PropertyColumnName String This property is the column name.
Public PropertyColumnType DbfMatchingPluginColumnType This property is the column type.
DbfMatchingPluginColumn(String, DbfMatchingPluginColumnType, Int32)
Name Type Description
columnName String<!– System.String –> This parameter is the column name.
columnType DbfMatchingPluginColumnType<!– ThinkGeo.MapSuite.MapSuiteGeocoder.DbfMatchingPluginColumnType –> This paramter is the column type.
columnLength Int32<!– System.Int32 –> This parameter is the column length.
Go Back
Return Type Description
Boolean<!– System.Boolean –> True if the specified Object is equal to the current Object; otherwise, false.
obj Object<!– System.Object –> The Object to compare with the current Object.
Int32<!– System.Int32 –> A hash code for the current Object.
Type<!– System.Type –>
String<!– System.String –> A String that represents the current object.
Void<!– System.Void –>
ColumnLength
Return Type
<!– ThinkGeo.MapSuite.MapSuiteGeocoder.DbfMatchingPluginColumn –> Go Back
ColumnName
Return Type
ColumnType
Return Type
thinkgeo.mapsuite.mapsuitegeocoder.dbfmatchingplugincolumn.1440040131.txt.gz · Last modified: 2015/09/21 07:03 (external edit)
