thinkgeo.mapsuite.iosedition.trackstartingtrackinteractiveoverlayeventargs
ThinkGeo.MapSuite.iOSEdition.TrackStartingTrackInteractiveOverlayEventArgs
<!– Class –> Provides data for the TrackStarting. event.
Public MethodTrackStartingTrackInteractiveOverlayEventArgs This is the default constructor of this parameter.
Public MethodTrackStartingTrackInteractiveOverlayEventArgs Vertex, Boolean This is the commonly used constructor.
Public MethodGetType Object
Public MethodToString Object
Public PropertyCancel Boolean This property gets or sets the action to be canceled or not.
Public PropertyStartingVertex Vertex This property gets or sets the started vertex when tracking shape action is being to start.
TrackStartingTrackInteractiveOverlayEventArgs()
Name Type Description
Go Back
TrackStartingTrackInteractiveOverlayEventArgs(Vertex, Boolean)
startingVertex Vertex<!– ThinkGeo.MapSuite.Core.Vertex –> This parameter specified the started vertex when tracking shape action is being to start.
cancel Boolean<!– System.Boolean –> This parameter specified the cancel property.
Go Back
Return Type Description
Int32<!– System.Int32 –>
Type<!– System.Type –>
String<!– System.String –>
Void<!– System.Void –>
Cancel
Return Type
<!– ThinkGeo.MapSuite.iOSEdition.TrackStartingTrackInteractiveOverlayEventArgs –> Go Back
StartingVertex
Return Type
thinkgeo.mapsuite.iosedition.trackstartingtrackinteractiveoverlayeventargs.1440040131.txt.gz · Last modified: 2015/09/21 08:34 (external edit)
