<!– Class –> Contains the different map tools as properties and acts as an entrance for setting these map controls.
This class is designed to be easy to use. It contains all the available tools of the map. You can find and set those map tools easily by using this class.
*System.Object
* iOSEdition System.Collections.ObjectModel.Collection‹T›[[ThinkGeo.MapSuite.iOSEdition.MapTool * PublicKeyToken=0828af5241fb4207]] Culture=neutral * Version=8.0.0.0 iOSEdition *ThinkGeo.MapSuite.Core.GeoCollection‹T›[[ThinkGeo.MapSuite.iOSEdition.MapTool ThinkGeo.MapSuite.iOSEdition.MapTools
ClearItems | Collection<MapTool>(overriden) | ||
InsertItem | Int32, MapTool | Collection<MapTool>(overriden) | |
MemberwiseClone | Object | ||
OnAdded | AddedGeoCollectionEventArgs | GeoCollection<MapTool> | |
OnAdding | AddingGeoCollectionEventArgs | GeoCollection<MapTool> | |
OnClearedItems | ClearedItemsGeoCollectionEventArgs | GeoCollection<MapTool> | |
OnClearingItems | ClearingItemsGeoCollectionEventArgs | GeoCollection<MapTool> | |
OnCollectionChanged | NotifyCollectionChangedEventArgs | GeoCollection<MapTool> | |
OnInserted | InsertedGeoCollectionEventArgs | GeoCollection<MapTool> | |
OnInserting | InsertingGeoCollectionEventArgs | GeoCollection<MapTool> | |
OnPropertyChanged | PropertyChangedEventArgs | GeoCollection<MapTool> | |
OnRemoved | RemovedGeoCollectionEventArgs | GeoCollection<MapTool> | |
OnRemoving | RemovingGeoCollectionEventArgs | GeoCollection<MapTool> | |
RemoveItem | Int32 | Collection<MapTool>(overriden) | |
SetItem | Int32, MapTool | Collection<MapTool>(overriden) |
CenterCoordinate | CenterCoordinateMapTool | Gets the center coordinate. | |
Count | Int32 | Collection<MapTool> | |
Item | MapTool | GeoCollection<MapTool> | |
Item | MapTool | Collection<MapTool> | |
ScaleLine | ScaleLineMapTool | Gets the scale line. | |
ZoomMapTool | ZoomMapTool | Gets the zoom map tool. |
| iOSMap | MapView<!– ThinkGeo.MapSuite.iOSEdition.MapView –> | A iOSMap object that all map tools in this object is based on. |
| item | MapTool<!– ThinkGeo.MapSuite.iOSEdition.MapTool –> |
<!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.iOSEdition.MapTool} –> Go Back
| key | String<!– System.String –> | |
<!– ThinkGeo.MapSuite.Core.GeoCollection{ThinkGeo.MapSuite.iOSEdition.MapTool} –> Go Back
| array | MapTool[]<!– ThinkGeo.MapSuite.iOSEdition.MapToolthinkgeo.mapsuite.iosedition.maptools –> | |
| index | Int32<!– System.Int32 –> |
| IEnumerator<MapTool><!– System.Collections.Generic.IEnumerator{ThinkGeo.MapSuite.iOSEdition.MapTool} –> |
| index | Int32<!– System.Int32 –> | |
| toIndex | Int32<!– System.Int32 –> |
| fromIndex | Int32<!– System.Int32 –> | |
| item | MapTool<!– ThinkGeo.MapSuite.iOSEdition.MapTool –> | |
Refreshes this instance.
<!– ThinkGeo.MapSuite.iOSEdition.MapTools –> Go Back
<!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.iOSEdition.MapTool}(overriden) –> Go Back
| e | AddedGeoCollectionEventArgs<!– ThinkGeo.MapSuite.Core.AddedGeoCollectionEventArgs –> |
| e | AddingGeoCollectionEventArgs<!– ThinkGeo.MapSuite.Core.AddingGeoCollectionEventArgs –> |
| e | ClearedItemsGeoCollectionEventArgs<!– ThinkGeo.MapSuite.Core.ClearedItemsGeoCollectionEventArgs –> |
| e | ClearingItemsGeoCollectionEventArgs<!– ThinkGeo.MapSuite.Core.ClearingItemsGeoCollectionEventArgs –> |
| e | NotifyCollectionChangedEventArgs<!– System.Collections.Specialized.NotifyCollectionChangedEventArgs –> |
| e | InsertedGeoCollectionEventArgs<!– ThinkGeo.MapSuite.Core.InsertedGeoCollectionEventArgs –> |
| e | InsertingGeoCollectionEventArgs<!– ThinkGeo.MapSuite.Core.InsertingGeoCollectionEventArgs –> |
| e | PropertyChangedEventArgs<!– System.ComponentModel.PropertyChangedEventArgs –> |
| e | RemovedGeoCollectionEventArgs<!– ThinkGeo.MapSuite.Core.RemovedGeoCollectionEventArgs –> |
| e | RemovingGeoCollectionEventArgs<!– ThinkGeo.MapSuite.Core.RemovingGeoCollectionEventArgs –> |
| CenterCoordinateMapTool<!– ThinkGeo.MapSuite.iOSEdition.CenterCoordinateMapTool –> |
| ScaleLineMapTool<!– ThinkGeo.MapSuite.iOSEdition.ScaleLineMapTool –> |
| ZoomMapTool<!– ThinkGeo.MapSuite.iOSEdition.ZoomMapTool –> |
| IList<MapTool><!– System.Collections.Generic.IList{ThinkGeo.MapSuite.iOSEdition.MapTool} –> |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
NOTOC iOSEdition ThinkGeo.MapSuite.iOSEdition UpdateDocumentation
