thinkgeo.mapsuite.iosedition.featurerotatingeditinteractiveoverlayeventargs
ThinkGeo.MapSuite.iOSEdition.FeatureRotatingEditInteractiveOverlayEventArgs
<!– Class –> Provides data for the FeatureRotating. event.
Public MethodFeatureRotatingEditInteractiveOverlayEventArgs This is the default constructor of this parameter.
Public MethodFeatureRotatingEditInteractiveOverlayEventArgs Feature, Boolean, PointShape, PointShape This is the commonly used constructor.
Public MethodGetType Object
Public MethodToString Object
Public PropertyCancel Boolean This property gets or sets the action to be canceled or not.
Public PropertyRotatingFeature Feature This property gets or sets the Feature to be used to roated.
Public PropertySourceControlPoint PointShape This property gets or sets the source control point to roate.
Public PropertyTargetControlPoint PointShape This property gets or sets the target control point to roate.
FeatureRotatingEditInteractiveOverlayEventArgs()
Name Type Description
Go Back
FeatureRotatingEditInteractiveOverlayEventArgs(Feature, Boolean, PointShape, PointShape)
rotatingFeature Feature<!– ThinkGeo.MapSuite.Core.Feature –> This parameter specified the target feature to be rotated.
cancel Boolean<!– System.Boolean –> This parameter specified the cancel property.
sourceControlPoint PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> This parameter specified the source control point to be roated.
targetControlPoint PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> This parameter specified the target control point to be roated.
Go Back
Return Type Description
Int32<!– System.Int32 –>
Type<!– System.Type –>
String<!– System.String –>
Void<!– System.Void –>
Cancel
Return Type
<!– ThinkGeo.MapSuite.iOSEdition.FeatureRotatingEditInteractiveOverlayEventArgs –> Go Back
RotatingFeature
Return Type
SourceControlPoint
Return Type
TargetControlPoint
Return Type
thinkgeo.mapsuite.iosedition.featurerotatingeditinteractiveoverlayeventargs.1440040131.txt.gz · Last modified: 2015/09/21 08:32 (external edit)
