<!– Class –> Provides data for the FeatureResized. event.
*System.Object System.EventArgs *ThinkGeo.MapSuite.iOSEdition.FeatureResizedEditInteractiveOverlayEventArgs
![]() | This is the default constructor of this parameter. | ||
![]() | Feature | This is the commonly used constructor. |
![]() | Object | Object | |
![]() | Object | ||
![]() | Object | ||
![]() | Object |
![]() | Object | ||
![]() | Object |
![]() | Feature | This property gets or sets the Feature resized. |
Name | Type | Description |
resizedFeature | Feature<!– ThinkGeo.MapSuite.Core.Feature –> | This parameter specified the feature resized. |
Return Type | Description |
Int32<!– System.Int32 –> |
Type<!– System.Type –> |
String<!– System.String –> |
Void<!– System.Void –> |
Return Type |
<!– ThinkGeo.MapSuite.iOSEdition.FeatureResizedEditInteractiveOverlayEventArgs –> Go Back
