<!– Class –>
*System.Object Newtonsoft.Json.JsonConverter *Newtonsoft.Json.Converters.DateTimeConverterBase Newtonsoft.Json.Converters.IsoDateTimeConverter *ThinkGeo.MapSuite.GisEditor.DateConverter
DateConverter |
CanConvert | Type | JsonConverter(overriden) | |
GetSchema | JsonConverter | ||
ReadJson | JsonReader, Type, Object, JsonSerializer | JsonConverter(overriden) | |
ToString | Object | ||
WriteJson | JsonWriter, Object, JsonSerializer | JsonConverter(overriden) |
CanRead | Boolean | JsonConverter | |
CanWrite | Boolean | JsonConverter | |
Culture | CultureInfo | IsoDateTimeConverter | |
DateTimeFormat | String | IsoDateTimeConverter | |
DateTimeStyles | DateTimeStyles | IsoDateTimeConverter |
| objectType | Type<!– System.Type –> |
<!– Newtonsoft.Json.JsonConverter(overriden) –> Go Back
| JsonSchema<!– Newtonsoft.Json.Schema.JsonSchema –> |
<!– Newtonsoft.Json.JsonConverter –> Go Back
| reader | JsonReader<!– Newtonsoft.Json.JsonReader –> | |
| objectType | Type<!– System.Type –> | |
| existingValue | Object<!– System.Object –> | |
| serializer | JsonSerializer<!– Newtonsoft.Json.JsonSerializer –> |
| writer | JsonWriter<!– Newtonsoft.Json.JsonWriter –> | |
| value | Object<!– System.Object –> | |
| CultureInfo<!– System.Globalization.CultureInfo –> |
<!– Newtonsoft.Json.Converters.IsoDateTimeConverter –> Go Back
| DateTimeStyles<!– System.Globalization.DateTimeStyles –> |
