thinkgeo.mapsuite.giseditor.columnnametoaliasnameconverter
ThinkGeo.MapSuite.GisEditor.ColumnNameToAliasNameConverter
<!– Class –>
Public MethodColumnNameToAliasNameConverter
Public MethodConvert Object[], Type, Object, CultureInfo
Public MethodConvertBack Object, Type[], Object, CultureInfo
Public MethodGetType Object
Public MethodToString Object
ColumnNameToAliasNameConverter()
Name Type Description
Go Back
Convert(Object[], Type, Object, CultureInfo)
Return Type Description
Object<!– System.Object –>
value Object[]<!– System.Objectthinkgeo.mapsuite.giseditor.columnnametoaliasnameconverter –>
targetType Type<!– System.Type –>
parameter Object<!– System.Object –>
culture CultureInfo<!– System.Globalization.CultureInfo –>
<!– ThinkGeo.MapSuite.GisEditor.ColumnNameToAliasNameConverter –> Go Back
ConvertBack(Object, Type[], Object, CultureInfo)
value Object<!– System.Object –>
targetTypes Type[]<!– System.Typethinkgeo.mapsuite.giseditor.columnnametoaliasnameconverter –>
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
String<!– System.String –>
Void<!– System.Void –>
thinkgeo.mapsuite.giseditor.columnnametoaliasnameconverter.txt · Last modified: 2017/03/16 21:59 (external edit)
