thinkgeo.mapsuite.desktopedition.trackstartingtrackinteractiveoverlayeventargs
ThinkGeo.MapSuite.DesktopEdition.TrackStartingTrackInteractiveOverlayEventArgs
Provides data for the TrackStarting event.
      • ThinkGeo.MapSuite.DesktopEdition.TrackStartingTrackInteractiveOverlayEventArgs
TrackStartingTrackInteractiveOverlayEventArgs()
  • If you use this constructor, you must set the properties manually before use.
TrackStartingTrackInteractiveOverlayEventArgs(Vertex,Boolean)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.TrackStartingTrackInteractiveOverlayEventArgs#TrackStartingTrackInteractiveOverlayEventArgs.28Vertex.2C_Boolean.29
  • startingVertex
    • Type:Vertex
    • Description:This parameter specifies the starting vertex used when the tracking shape action is being started.
  • cancel
    • Description:This parameter specifies the cancel property.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.TrackStartingTrackInteractiveOverlayEventArgs#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.TrackStartingTrackInteractiveOverlayEventArgs#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.TrackStartingTrackInteractiveOverlayEventArgs#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.TrackStartingTrackInteractiveOverlayEventArgs#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.TrackStartingTrackInteractiveOverlayEventArgs#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.TrackStartingTrackInteractiveOverlayEventArgs#MemberwiseClone.28.29
Cancel
This property gets or sets whether the action will be canceled or not.
StartingVertex
This property gets or sets the starting vertex used when the tracking shape action is being started.
thinkgeo.mapsuite.desktopedition.trackstartingtrackinteractiveoverlayeventargs.1442909594.txt.gz · Last modified: 2015/09/22 08:13 by admin
