thinkgeo.mapsuite.desktopedition.trackstartingtrackinteractiveoverlayeventargs
ThinkGeo.MapSuite.DesktopEdition.TrackStartingTrackInteractiveOverlayEventArgs
Provides data for the TrackStarting event.
      • ThinkGeo.MapSuite.DesktopEdition.TrackStartingTrackInteractiveOverlayEventArgs
TrackStartingTrackInteractiveOverlayEventArgs()
TrackStartingTrackInteractiveOverlayEventArgs(Vertex,Boolean)
  • startingVertex
    • Type:Vertex
    • Description:This parameter specifies the starting vertex used when the tracking shape action is being started.
  • cancel
    • Description:This parameter specifies the cancel property.
Cancel
This property gets or sets whether the action will be canceled or not.
StartingVertex
This property gets or sets the starting vertex used when the tracking shape action is being started.
thinkgeo.mapsuite.desktopedition.trackstartingtrackinteractiveoverlayeventargs.1442545495.txt.gz · Last modified: 2015/09/18 03:04 by admin
