<!– Class –> This class stores the information for Pan and Track Zoom.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.PanAndTrackZoomState” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.PanAndTrackZoomState</a>
*System.Object **ThinkGeo.MapSuite.DesktopEdition.PanAndTrackZoomState
PanAndTrackZoomState | Default constructor of this class. |
GetNewExtent | ScreenPointF, RectangleShape, Double, Double | This method is used to get an updated extent for interative action. | |
EndXInScreen | Single | This property gets or sets the ending screen X when interative action ends. | |
EndYInScreen | Single | This property gets or sets the ending screen Y when interative action ends. | |
IsLeftClickDragKeyPressed | Boolean | This property gets or sets the status of whether the left click drag key is pressed or not. | |
IsMouseLeftButtonDown | Boolean | This property gets or sets the status of whether the left mouse button is pressed down or not. | |
IsMouseRightButtonDown | Boolean | This property gets or sets the status of whether the right mouse button is pressed down or not. | |
IsRightClickDragKeyPressed | Boolean | This property gets or sets the status of whether the right click drag key is pressed or not. | |
LowRightPoint | ScreenPointF | This property gets the lower right screen point. | |
MouseMoveStartExtent | RectangleShape | This property gets and sets the extent when the mouse move starts. | |
OffsetXInScreen | Int32 | This property gets screen offset X distance. | |
OffsetYInScreen | Int32 | This property gets screen offset Y distance. | |
StartXInScreen | Single | This property gets or sets the starting screen X when interative action starts. | |
StartYInScreen | Single | This property gets or sets the starting screen Y when interative action starts. | |
UpperLeftPoint | ScreenPointF | This property gets the upper left screen point. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.PanAndTrackZoomState#PanAndTrackZoomState.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.PanAndTrackZoomState#PanAndTrackZoomState.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.PanAndTrackZoomState#Equals.28Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.PanAndTrackZoomState#Equals.28Object.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.PanAndTrackZoomState#GetHashCode.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.PanAndTrackZoomState#GetHashCode.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.PanAndTrackZoomState#GetNewExtent.28ScreenPointF.2C_RectangleShape.2C_Double.2C_Double.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.PanAndTrackZoomState#GetNewExtent.28ScreenPointF.2C_RectangleShape.2C_Double.2C_Double.29</a>
| RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | Returns a updated extent which will replace the current extent. |
| location | ScreenPointF<!– ThinkGeo.MapSuite.Core.ScreenPointF –> | This parameter specifies the current location of the mouse. |
| currentExtent | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | This parameter specifies the current extent. |
| width | Double<!– System.Double –> | This parameter specifies the width of the extent in screen units. |
| height | Double<!– System.Double –> | This parameter specifies the height of the extent in screen units. |
<!– ThinkGeo.MapSuite.DesktopEdition.PanAndTrackZoomState –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.PanAndTrackZoomState#GetType.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.PanAndTrackZoomState#GetType.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.PanAndTrackZoomState#ToString.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.PanAndTrackZoomState#ToString.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.PanAndTrackZoomState#Finalize.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.PanAndTrackZoomState#Finalize.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.PanAndTrackZoomState#MemberwiseClone.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.PanAndTrackZoomState#MemberwiseClone.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.PanAndTrackZoomState#EndXInScreen” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.PanAndTrackZoomState#EndXInScreen</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.PanAndTrackZoomState#EndYInScreen” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.PanAndTrackZoomState#EndYInScreen</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.PanAndTrackZoomState#IsLeftClickDragKeyPressed” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.PanAndTrackZoomState#IsLeftClickDragKeyPressed</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.PanAndTrackZoomState#IsMouseLeftButtonDown” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.PanAndTrackZoomState#IsMouseLeftButtonDown</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.PanAndTrackZoomState#IsMouseRightButtonDown” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.PanAndTrackZoomState#IsMouseRightButtonDown</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.PanAndTrackZoomState#IsRightClickDragKeyPressed” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.PanAndTrackZoomState#IsRightClickDragKeyPressed</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.PanAndTrackZoomState#LowRightPoint” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.PanAndTrackZoomState#LowRightPoint</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.PanAndTrackZoomState#MouseMoveStartExtent” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.PanAndTrackZoomState#MouseMoveStartExtent</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.PanAndTrackZoomState#OffsetXInScreen” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.PanAndTrackZoomState#OffsetXInScreen</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.PanAndTrackZoomState#OffsetYInScreen” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.PanAndTrackZoomState#OffsetYInScreen</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.PanAndTrackZoomState#StartXInScreen” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.PanAndTrackZoomState#StartXInScreen</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.PanAndTrackZoomState#StartYInScreen” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.PanAndTrackZoomState#StartYInScreen</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.PanAndTrackZoomState#UpperLeftPoint” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.PanAndTrackZoomState#UpperLeftPoint</a>
