thinkgeo.mapsuite.desktopedition.mapmouseupinteractiveoverlayeventargs
ThinkGeo.MapSuite.DesktopEdition.MapMouseUpInteractiveOverlayEventArgs
Provides data for the MapMouseUp event.
      • ThinkGeo.MapSuite.DesktopEdition.MapMouseUpInteractiveOverlayEventArgs
MapMouseUpInteractiveOverlayEventArgs()
MapMouseUpInteractiveOverlayEventArgs(InteractionArguments)
  • interactionArguments
    • Description:This parameter specifies the interaction arguments used to construct the class.
This property gets the interaction arguments for the event args.
thinkgeo.mapsuite.desktopedition.mapmouseupinteractiveoverlayeventargs.1442545398.txt.gz · Last modified: 2015/09/18 03:03 by admin
