thinkgeo.mapsuite.desktopedition.mapmousedoubleclickinteractiveoverlayeventargs
ThinkGeo.MapSuite.DesktopEdition.MapMouseDoubleClickInteractiveOverlayEventArgs
Provides data for the MapMouseDoubleClick event.
      • ThinkGeo.MapSuite.DesktopEdition.MapMouseDoubleClickInteractiveOverlayEventArgs
MapMouseDoubleClickInteractiveOverlayEventArgs()
  • If you use this constructor, you must set the properties manually before use.
MapMouseDoubleClickInteractiveOverlayEventArgs(InteractionArguments)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapMouseDoubleClickInteractiveOverlayEventArgs#MapMouseDoubleClickInteractiveOverlayEventArgs.28InteractionArguments.29
  • interactionArguments
    • Description:This parameter specifies the interaction arguments used to construct the class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapMouseDoubleClickInteractiveOverlayEventArgs#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapMouseDoubleClickInteractiveOverlayEventArgs#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapMouseDoubleClickInteractiveOverlayEventArgs#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapMouseDoubleClickInteractiveOverlayEventArgs#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapMouseDoubleClickInteractiveOverlayEventArgs#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapMouseDoubleClickInteractiveOverlayEventArgs#MemberwiseClone.28.29
  • This property gets the interaction arguments for the event args.
thinkgeo.mapsuite.desktopedition.mapmousedoubleclickinteractiveoverlayeventargs.1442966446.txt.gz · Last modified: 2015/09/23 00:00 (external edit)
