thinkgeo.mapsuite.desktopedition.mapmousedoubleclickinteractiveoverlayeventargs
ThinkGeo.MapSuite.DesktopEdition.MapMouseDoubleClickInteractiveOverlayEventArgs
Provides data for the MapMouseDoubleClick event.
      • ThinkGeo.MapSuite.DesktopEdition.MapMouseDoubleClickInteractiveOverlayEventArgs
MapMouseDoubleClickInteractiveOverlayEventArgs()
MapMouseDoubleClickInteractiveOverlayEventArgs(InteractionArguments)
  • interactionArguments
    • Description:This parameter specifies the interaction arguments used to construct the class.
This property gets the interaction arguments for the event args.
thinkgeo.mapsuite.desktopedition.mapmousedoubleclickinteractiveoverlayeventargs.1442545393.txt.gz · Last modified: 2015/09/18 03:03 by admin
