thinkgeo.mapsuite.desktopedition.mapmouseclickinteractiveoverlayeventargs
ThinkGeo.MapSuite.DesktopEdition.MapMouseClickInteractiveOverlayEventArgs
Provides data for the MapMouseClick event.
      • ThinkGeo.MapSuite.DesktopEdition.MapMouseClickInteractiveOverlayEventArgs
MapMouseClickInteractiveOverlayEventArgs()
  • If you use this constructor, you must set the properties manually before use.
MapMouseClickInteractiveOverlayEventArgs(InteractionArguments)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapMouseClickInteractiveOverlayEventArgs#MapMouseClickInteractiveOverlayEventArgs.28InteractionArguments.29
  • interactionArguments
    • Description:This parameter specifies the interaction arguments used to construct the class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapMouseClickInteractiveOverlayEventArgs#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapMouseClickInteractiveOverlayEventArgs#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapMouseClickInteractiveOverlayEventArgs#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapMouseClickInteractiveOverlayEventArgs#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapMouseClickInteractiveOverlayEventArgs#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapMouseClickInteractiveOverlayEventArgs#MemberwiseClone.28.29
  • This property gets the interaction arguments for the mouse click event args.
thinkgeo.mapsuite.desktopedition.mapmouseclickinteractiveoverlayeventargs.1442966445.txt.gz · Last modified: 2015/09/23 00:00 by admin
