thinkgeo.mapsuite.desktopedition.mapmouseclickinteractiveoverlayeventargs
ThinkGeo.MapSuite.DesktopEdition.MapMouseClickInteractiveOverlayEventArgs
Provides data for the MapMouseClick event.
      • ThinkGeo.MapSuite.DesktopEdition.MapMouseClickInteractiveOverlayEventArgs
MapMouseClickInteractiveOverlayEventArgs()
MapMouseClickInteractiveOverlayEventArgs(InteractionArguments)
  • interactionArguments
    • Description:This parameter specifies the interaction arguments used to construct the class.
This property gets the interaction arguments for the mouse click event args.
thinkgeo.mapsuite.desktopedition.mapmouseclickinteractiveoverlayeventargs.1442545392.txt.gz · Last modified: 2015/09/18 03:03 by admin
