<!– Class –> Provides data for the MapMouseClick event.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapMouseClickInteractiveOverlayEventArgs” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapMouseClickInteractiveOverlayEventArgs</a>
*System.Object System.EventArgs *ThinkGeo.MapSuite.DesktopEdition.MapMouseClickInteractiveOverlayEventArgs
MapMouseClickInteractiveOverlayEventArgs | This is the default constructor of this parameter. | ||
MapMouseClickInteractiveOverlayEventArgs | InteractionArguments | This is the commonly used constructor. |
InteractionArguments | InteractionArguments | This property gets the interaction arguments for the mouse click event args. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapMouseClickInteractiveOverlayEventArgs#MapMouseClickInteractiveOverlayEventArgs.28InteractionArguments.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapMouseClickInteractiveOverlayEventArgs#MapMouseClickInteractiveOverlayEventArgs.28InteractionArguments.29</a>
| interactionArguments | InteractionArguments<!– ThinkGeo.MapSuite.DesktopEdition.InteractionArguments –> | This parameter specifies the interaction arguments used to construct the class. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapMouseClickInteractiveOverlayEventArgs#Equals.28Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapMouseClickInteractiveOverlayEventArgs#Equals.28Object.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapMouseClickInteractiveOverlayEventArgs#GetHashCode.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapMouseClickInteractiveOverlayEventArgs#GetHashCode.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapMouseClickInteractiveOverlayEventArgs#GetType.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapMouseClickInteractiveOverlayEventArgs#GetType.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapMouseClickInteractiveOverlayEventArgs#ToString.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapMouseClickInteractiveOverlayEventArgs#ToString.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapMouseClickInteractiveOverlayEventArgs#Finalize.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapMouseClickInteractiveOverlayEventArgs#Finalize.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapMouseClickInteractiveOverlayEventArgs#MemberwiseClone.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapMouseClickInteractiveOverlayEventArgs#MemberwiseClone.28.29</a>
<!– ThinkGeo.MapSuite.DesktopEdition.MapMouseClickInteractiveOverlayEventArgs –> Go Back
