<!– Class –> Provides data for the MapKeyDown event.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapKeyDownInteractiveOverlayEventArgs” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapKeyDownInteractiveOverlayEventArgs</a>
*System.Object System.EventArgs *ThinkGeo.MapSuite.DesktopEdition.MapKeyDownInteractiveOverlayEventArgs
MapKeyDownInteractiveOverlayEventArgs | This is the default constructor of this parameter. | ||
MapKeyDownInteractiveOverlayEventArgs | KeyEventInteractionArguments | This is the commonly used constructor. |
InteractionArguments | KeyEventInteractionArguments | This property gets the interaction arguments for the event args. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapKeyDownInteractiveOverlayEventArgs#MapKeyDownInteractiveOverlayEventArgs.28KeyEventInteractionArguments.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapKeyDownInteractiveOverlayEventArgs#MapKeyDownInteractiveOverlayEventArgs.28KeyEventInteractionArguments.29</a>
| interactionArguments | KeyEventInteractionArguments<!– ThinkGeo.MapSuite.DesktopEdition.KeyEventInteractionArguments –> | This parameter specified the interaction arguments to construct the class. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapKeyDownInteractiveOverlayEventArgs#Equals.28Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapKeyDownInteractiveOverlayEventArgs#Equals.28Object.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapKeyDownInteractiveOverlayEventArgs#GetHashCode.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapKeyDownInteractiveOverlayEventArgs#GetHashCode.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapKeyDownInteractiveOverlayEventArgs#GetType.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapKeyDownInteractiveOverlayEventArgs#GetType.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapKeyDownInteractiveOverlayEventArgs#ToString.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapKeyDownInteractiveOverlayEventArgs#ToString.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapKeyDownInteractiveOverlayEventArgs#Finalize.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapKeyDownInteractiveOverlayEventArgs#Finalize.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapKeyDownInteractiveOverlayEventArgs#MemberwiseClone.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapKeyDownInteractiveOverlayEventArgs#MemberwiseClone.28.29</a>
<!– ThinkGeo.MapSuite.DesktopEdition.MapKeyDownInteractiveOverlayEventArgs –> Go Back
