thinkgeo.mapsuite.desktopedition.featurerotatingeditinteractiveoverlayeventargs
ThinkGeo.MapSuite.DesktopEdition.FeatureRotatingEditInteractiveOverlayEventArgs
Provides data for the FeatureRotating event.
      • ThinkGeo.MapSuite.DesktopEdition.FeatureRotatingEditInteractiveOverlayEventArgs
FeatureRotatingEditInteractiveOverlayEventArgs()
FeatureRotatingEditInteractiveOverlayEventArgs(Feature,Boolean,PointShape,PointShape)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureRotatingEditInteractiveOverlayEventArgs#FeatureRotatingEditInteractiveOverlayEventArgs.28Feature.2C_Boolean.2C_PointShape.2C_PointShape.29
  • rotatingFeature
    • Type:Feature
    • Description:This parameter specifies the target feature to be rotated.
  • cancel
    • Description:This parameter specifies the cancel property.
  • sourceControlPoint
    • Description:This parameter specifies the source control point to be rotated.
  • targetControlPoint
    • Description:This parameter specifies the target control point to be rotated.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureRotatingEditInteractiveOverlayEventArgs#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureRotatingEditInteractiveOverlayEventArgs#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureRotatingEditInteractiveOverlayEventArgs#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureRotatingEditInteractiveOverlayEventArgs#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureRotatingEditInteractiveOverlayEventArgs#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureRotatingEditInteractiveOverlayEventArgs#MemberwiseClone.28.29
RotatingFeature
  • This property gets or sets the Feature to be rotated.
TargetControlPoint
  • This property gets or sets the target control point to rotate.
thinkgeo.mapsuite.desktopedition.featurerotatingeditinteractiveoverlayeventargs.1442966411.txt.gz · Last modified: 2015/09/23 00:00 by admin
