<!– Class –> Provides data for the FeatureRotating event.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureRotatingEditInteractiveOverlayEventArgs” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureRotatingEditInteractiveOverlayEventArgs</a>
*System.Object System.EventArgs *ThinkGeo.MapSuite.DesktopEdition.FeatureRotatingEditInteractiveOverlayEventArgs
FeatureRotatingEditInteractiveOverlayEventArgs | This is the default constructor of this parameter. | ||
FeatureRotatingEditInteractiveOverlayEventArgs | Feature, Boolean, PointShape, PointShape | This is the commonly used constructor. |
Cancel | Boolean | This property gets or sets whether or not the action will be canceled. | |
RotatingFeature | Feature | This property gets or sets the Feature to be rotated. | |
SourceControlPoint | PointShape | This property gets or sets the source control point to rotate. | |
TargetControlPoint | PointShape | This property gets or sets the target control point to rotate. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureRotatingEditInteractiveOverlayEventArgs#FeatureRotatingEditInteractiveOverlayEventArgs.28Feature.2C_Boolean.2C_PointShape.2C_PointShape.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureRotatingEditInteractiveOverlayEventArgs#FeatureRotatingEditInteractiveOverlayEventArgs.28Feature.2C_Boolean.2C_PointShape.2C_PointShape.29</a>
| rotatingFeature | Feature<!– ThinkGeo.MapSuite.Core.Feature –> | This parameter specifies the target feature to be rotated. |
| cancel | Boolean<!– System.Boolean –> | This parameter specifies the cancel property. |
| sourceControlPoint | PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> | This parameter specifies the source control point to be rotated. |
| targetControlPoint | PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> | This parameter specifies the target control point to be rotated. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureRotatingEditInteractiveOverlayEventArgs#Equals.28Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureRotatingEditInteractiveOverlayEventArgs#Equals.28Object.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureRotatingEditInteractiveOverlayEventArgs#GetHashCode.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureRotatingEditInteractiveOverlayEventArgs#GetHashCode.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureRotatingEditInteractiveOverlayEventArgs#GetType.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureRotatingEditInteractiveOverlayEventArgs#GetType.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureRotatingEditInteractiveOverlayEventArgs#ToString.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureRotatingEditInteractiveOverlayEventArgs#ToString.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureRotatingEditInteractiveOverlayEventArgs#Finalize.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureRotatingEditInteractiveOverlayEventArgs#Finalize.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureRotatingEditInteractiveOverlayEventArgs#MemberwiseClone.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureRotatingEditInteractiveOverlayEventArgs#MemberwiseClone.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureRotatingEditInteractiveOverlayEventArgs#Cancel” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureRotatingEditInteractiveOverlayEventArgs#Cancel</a>
<!– ThinkGeo.MapSuite.DesktopEdition.FeatureRotatingEditInteractiveOverlayEventArgs –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureRotatingEditInteractiveOverlayEventArgs#RotatingFeature” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureRotatingEditInteractiveOverlayEventArgs#RotatingFeature</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureRotatingEditInteractiveOverlayEventArgs#SourceControlPoint” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureRotatingEditInteractiveOverlayEventArgs#SourceControlPoint</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureRotatingEditInteractiveOverlayEventArgs#TargetControlPoint” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureRotatingEditInteractiveOverlayEventArgs#TargetControlPoint</a>
