thinkgeo.mapsuite.desktopedition.featureresizingeditinteractiveoverlayeventargs
ThinkGeo.MapSuite.DesktopEdition.FeatureResizingEditInteractiveOverlayEventArgs
Provides data for the FeatureResizing event.
      • ThinkGeo.MapSuite.DesktopEdition.FeatureResizingEditInteractiveOverlayEventArgs
FeatureResizingEditInteractiveOverlayEventArgs()
FeatureResizingEditInteractiveOverlayEventArgs(Feature,Boolean,PointShape,PointShape)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureResizingEditInteractiveOverlayEventArgs#FeatureResizingEditInteractiveOverlayEventArgs.28Feature.2C_Boolean.2C_PointShape.2C_PointShape.29
  • resizingFeature
    • Type:Feature
    • Description:This parameter specifies the target feature to be resized.
  • cancel
    • Description:This parameter specifies the cancel property.
  • sourceControlPoint
    • Description:This parameter specifies the source control point to be resized.
  • targetControlPoint
    • Description:This parameter specifies the target control point to be resized.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureResizingEditInteractiveOverlayEventArgs#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureResizingEditInteractiveOverlayEventArgs#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureResizingEditInteractiveOverlayEventArgs#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureResizingEditInteractiveOverlayEventArgs#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureResizingEditInteractiveOverlayEventArgs#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureResizingEditInteractiveOverlayEventArgs#MemberwiseClone.28.29
ResizingFeature
  • This property gets or sets the Feature to be resized.
TargetControlPoint
  • This property gets or sets the target control point to resize.
thinkgeo.mapsuite.desktopedition.featureresizingeditinteractiveoverlayeventargs.1442966407.txt.gz · Last modified: 2015/09/23 00:00 by admin
