thinkgeo.mapsuite.desktopedition.featureresizingeditinteractiveoverlayeventargs
ThinkGeo.MapSuite.DesktopEdition.FeatureResizingEditInteractiveOverlayEventArgs
Provides data for the FeatureResizing event.
      • ThinkGeo.MapSuite.DesktopEdition.FeatureResizingEditInteractiveOverlayEventArgs
FeatureResizingEditInteractiveOverlayEventArgs()
FeatureResizingEditInteractiveOverlayEventArgs(Feature,Boolean,PointShape,PointShape)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureResizingEditInteractiveOverlayEventArgs#FeatureResizingEditInteractiveOverlayEventArgs.28Feature.2C_Boolean.2C_PointShape.2C_PointShape.29
  • resizingFeature
    • Type:Feature
    • Description:This parameter specifies the target feature to be resized.
  • cancel
    • Description:This parameter specifies the cancel property.
  • sourceControlPoint
    • Description:This parameter specifies the source control point to be resized.
  • targetControlPoint
    • Description:This parameter specifies the target control point to be resized.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureResizingEditInteractiveOverlayEventArgs#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureResizingEditInteractiveOverlayEventArgs#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureResizingEditInteractiveOverlayEventArgs#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureResizingEditInteractiveOverlayEventArgs#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureResizingEditInteractiveOverlayEventArgs#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureResizingEditInteractiveOverlayEventArgs#MemberwiseClone.28.29
ResizingFeature
This property gets or sets the Feature to be resized.
SourceControlPoint
This property gets or sets the source control point to resize.
TargetControlPoint
This property gets or sets the target control point to resize.
Cancel
This property gets or sets whether or not the action will be canceled.
thinkgeo.mapsuite.desktopedition.featureresizingeditinteractiveoverlayeventargs.1442909465.txt.gz · Last modified: 2015/09/22 08:11 by admin
