thinkgeo.mapsuite.desktopedition.featuredraggededitinteractiveoverlayeventargs
ThinkGeo.MapSuite.DesktopEdition.FeatureDraggedEditInteractiveOverlayEventArgs
Provides data for the FeatureDragged event.
      • ThinkGeo.MapSuite.DesktopEdition.FeatureDraggedEditInteractiveOverlayEventArgs
FeatureDraggedEditInteractiveOverlayEventArgs()
FeatureDraggedEditInteractiveOverlayEventArgs(Feature)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureDraggedEditInteractiveOverlayEventArgs#FeatureDraggedEditInteractiveOverlayEventArgs.28Feature.29
  • draggedFeature
    • Type:Feature
    • Description:This parameter specifies the feature dragged.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureDraggedEditInteractiveOverlayEventArgs#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureDraggedEditInteractiveOverlayEventArgs#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureDraggedEditInteractiveOverlayEventArgs#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureDraggedEditInteractiveOverlayEventArgs#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureDraggedEditInteractiveOverlayEventArgs#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureDraggedEditInteractiveOverlayEventArgs#MemberwiseClone.28.29
DraggedFeature
  • This property gets or sets the Feature dragged.
thinkgeo.mapsuite.desktopedition.featuredraggededitinteractiveoverlayeventargs.1442966402.txt.gz · Last modified: 2015/09/23 00:00 by admin
