thinkgeo.mapsuite.desktopedition.controlpointselectededitinteractiveoverlayeventargs
ThinkGeo.MapSuite.DesktopEdition.ControlPointSelectedEditInteractiveOverlayEventArgs
Provides data for the ControlPointSelected event.
      • ThinkGeo.MapSuite.DesktopEdition.ControlPointSelectedEditInteractiveOverlayEventArgs
ControlPointSelectedEditInteractiveOverlayEventArgs()
ControlPointSelectedEditInteractiveOverlayEventArgs(Feature)
  • selectedFeature
    • Type:Feature
    • Description:This parameter specifies the feature selected.
SelectedFeature
This property gets or sets the selected feature.
thinkgeo.mapsuite.desktopedition.controlpointselectededitinteractiveoverlayeventargs.1442545308.txt.gz · Last modified: 2015/09/18 03:01 by admin
