thinkgeo.mapsuite.core.zoomlevelset
ThinkGeo.MapSuite.Core.ZoomLevelSet
ZoomLevelSet()
This constructor is where we set the default scales for each ZoomLevel. If you inherit from this class to create your own custom ZoomSet, then you should not call the base constructor if you want to supply your own custom ZoomLevels.
GetZoomLevel(RectangleShape,Double,GeographyUnit)
This method returns the active ZoomLevel based on an extent, a map unit and a screen width.
  • Type:ZoomLevel
  • Description:This method returns the active ZoomLevel based on an extent, a map unit and a screen width.
  • extent
  • screenWidth
    • Description:This parameter is the width of the map in pixels.
  • mapUnit
    • Description:This parameter is the unit of the map.
GetZoomLevel(RectangleShape,Double,GeographyUnit,Single)
  • Type:ZoomLevel
  • extent
  • screenWidth
  • mapUnit
  • dpi
    • Type:Single
    • Description:This parameter is the dpi of the extent.
GetZoomLevelForDrawing(RectangleShape,Double,GeographyUnit,Single)
This method returns the active ZoomLevel based on an extent, a map unit and a canvas width.
  • Type:ZoomLevel
  • Description:This method returns the active ZoomLevel based on an extent, map unit and a canvas width.
  • extent
  • screenWidth
    • Description:This parameter is the width of the canvas in pixels.
  • mapUnit
  • dpi
    • Type:Single
GetZoomLevelForDrawing(RectangleShape,Double,GeographyUnit)
  • Type:ZoomLevel
  • extent
  • screenWidth
  • mapUnit
GetZoomLevels()
This method return all of the zoomLevels in the zoomLevelSet.
None.
  • Type:Collection<ZoomLevel>
  • Description:This method return all of the zoomlevels in the zoomLevelSet.
GetLowerZoomLevelScale(Double,ZoomLevelSet)
ZoomToScale in, the result is less than input
  • currentScale
GetHigherZoomLevelScale(Double,ZoomLevelSet)
ZoomToScale out, the result is greater than input
  • currentScale
hGU=(Double)
  • hWU=
This property gets and sets the name for the ZoomSet.
CustomZoomLevels
This property gets the custom zoom levels from the zoomLevelSet.
ZoomLevel01
This property gets the ZoomLevel for Level01.
ZoomLevel02
This property gets the ZoomLevel for Level02.
ZoomLevel03
This property gets the ZoomLevel for Level03.
ZoomLevel04
This property gets the ZoomLevel for Level04.
ZoomLevel05
This property gets the ZoomLevel for Level05.
ZoomLevel06
This property gets the ZoomLevel for Level06.
ZoomLevel07
This property gets the ZoomLevel for Level07.
ZoomLevel08
This property gets the ZoomLevel for Level08.
ZoomLevel09
This property gets the ZoomLevel for Level09.
ZoomLevel10
This property gets the ZoomLevel for Level10.
ZoomLevel11
This property gets the ZoomLevel for Level11.
ZoomLevel12
This property gets the ZoomLevel for Level12.
ZoomLevel13
This property gets the ZoomLevel for Level13.
ZoomLevel14
This property gets the ZoomLevel for Level14.
ZoomLevel15
This property gets the ZoomLevel for Level15.
ZoomLevel16
This property gets the ZoomLevel for Level16.
ZoomLevel17
This property gets the ZoomLevel for Level17.
ZoomLevel18
This property gets the ZoomLevel for Level18.
ZoomLevel19
This property gets the ZoomLevel for Level19.
ZoomLevel20
This property gets the ZoomLevel for Level20.
thinkgeo.mapsuite.core.zoomlevelset.1442797957.txt.gz · Last modified: 2015/09/21 01:12 by admin
