This constructor is where we set the default scales for each ZoomLevel. If you inherit from this class to create your own custom ZoomSet, then you should not call the base constructor if you want to supply your own custom ZoomLevels.
ZoomToScale out, the result is greater than input
ZoomToScale in, the result is less than input
This method returns the active ZoomLevel based on an extent, a map unit and a screen width.
extent
screenWidth
mapUnit
extent
screenWidth
mapUnit
dpi
This method returns the active ZoomLevel based on an extent, a map unit and a canvas width.
extent
screenWidth
mapUnit
dpi
extent
screenWidth
mapUnit
This method return all of the zoomLevels in the zoomLevelSet.
None.
This property gets the custom zoom levels from the zoomLevelSet.
This property gets and sets the name for the ZoomSet.
Return Type:String
This property gets the ZoomLevel for Level01.
This property gets the ZoomLevel for Level02.
This property gets the ZoomLevel for Level03.
This property gets the ZoomLevel for Level04.
This property gets the ZoomLevel for Level05.
This property gets the ZoomLevel for Level06.
This property gets the ZoomLevel for Level07.
This property gets the ZoomLevel for Level08.
This property gets the ZoomLevel for Level09.
This property gets the ZoomLevel for Level10.
This property gets the ZoomLevel for Level11.
This property gets the ZoomLevel for Level12.
This property gets the ZoomLevel for Level13.
This property gets the ZoomLevel for Level14.
This property gets the ZoomLevel for Level15.
This property gets the ZoomLevel for Level16.
This property gets the ZoomLevel for Level17.
This property gets the ZoomLevel for Level18.
This property gets the ZoomLevel for Level19.
This property gets the ZoomLevel for Level20.
