thinkgeo.mapsuite.core.zoomlevelset
ThinkGeo.MapSuite.Core.ZoomLevelSet
This class represents a collection of ZoomLevels. Each ZoomLevel has a different scale and can store Styles that determine how InternalFeatures draw.
Public MethodZoomLevelSet This is the default constructor.
Public MethodStatic MemberGetHigherZoomLevelScale Double, ZoomLevelSet ZoomToScale out, the result is greater than input
Public MethodStatic MemberGetLowerZoomLevelScale Double, ZoomLevelSet ZoomToScale in, the result is less than input
Public MethodGetType Object
Public MethodGetZoomLevel RectangleShape, Double, GeographyUnit This method returns the active ZoomLevel based on an extent, a map unit and a screen width.
Public MethodGetZoomLevel RectangleShape, Double, GeographyUnit, Single This method returns the active ZoomLevel based on an extent, a map unit and a screen width.
Public MethodGetZoomLevelForDrawing RectangleShape, Double, GeographyUnit, Single This method returns the active ZoomLevel based on an extent, a map unit and a canvas width.
Public MethodGetZoomLevelForDrawing RectangleShape, Double, GeographyUnit This method returns the active ZoomLevel based on an extent, a map unit and a canvas width.
Public MethodGetZoomLevels This method return all of the zoomLevels in the zoomLevelSet.
Public MethodToString Object
Public PropertyCustomZoomLevels Collection<ZoomLevel> This property gets the custom zoom levels from the zoomLevelSet.
Public PropertyName String This property gets and sets the name for the ZoomSet.
Public PropertyZoomLevel01 ZoomLevel This property gets the ZoomLevel for Level01.
Public PropertyZoomLevel02 ZoomLevel This property gets the ZoomLevel for Level02.
Public PropertyZoomLevel03 ZoomLevel This property gets the ZoomLevel for Level03.
Public PropertyZoomLevel04 ZoomLevel This property gets the ZoomLevel for Level04.
Public PropertyZoomLevel05 ZoomLevel This property gets the ZoomLevel for Level05.
Public PropertyZoomLevel06 ZoomLevel This property gets the ZoomLevel for Level06.
Public PropertyZoomLevel07 ZoomLevel This property gets the ZoomLevel for Level07.
Public PropertyZoomLevel08 ZoomLevel This property gets the ZoomLevel for Level08.
Public PropertyZoomLevel09 ZoomLevel This property gets the ZoomLevel for Level09.
Public PropertyZoomLevel10 ZoomLevel This property gets the ZoomLevel for Level10.
Public PropertyZoomLevel11 ZoomLevel This property gets the ZoomLevel for Level11.
Public PropertyZoomLevel12 ZoomLevel This property gets the ZoomLevel for Level12.
Public PropertyZoomLevel13 ZoomLevel This property gets the ZoomLevel for Level13.
Public PropertyZoomLevel14 ZoomLevel This property gets the ZoomLevel for Level14.
Public PropertyZoomLevel15 ZoomLevel This property gets the ZoomLevel for Level15.
Public PropertyZoomLevel16 ZoomLevel This property gets the ZoomLevel for Level16.
Public PropertyZoomLevel17 ZoomLevel This property gets the ZoomLevel for Level17.
Public PropertyZoomLevel18 ZoomLevel This property gets the ZoomLevel for Level18.
Public PropertyZoomLevel19 ZoomLevel This property gets the ZoomLevel for Level19.
Public PropertyZoomLevel20 ZoomLevel This property gets the ZoomLevel for Level20.
ZoomLevelSet()
This constructor is where we set the default scales for each ZoomLevel. If you inherit from this class to create your own custom ZoomSet, then you should not call the base constructor if you want to supply your own custom ZoomLevels.
Name Type Description
Go Back
Return Type Description
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
GetHigherZoomLevelScale(Double, ZoomLevelSet)
Double<!– System.Double –>
currentScale Double<!– System.Double –>
zoomLevelSet ZoomLevelSet<!– ThinkGeo.MapSuite.Core.ZoomLevelSet –>
<!– ThinkGeo.MapSuite.Core.ZoomLevelSet –> Go Back
GetLowerZoomLevelScale(Double, ZoomLevelSet)
Type<!– System.Type –>
GetZoomLevel(RectangleShape, Double, GeographyUnit)
ZoomLevel<!– ThinkGeo.MapSuite.Core.ZoomLevel –> This method returns the active ZoomLevel based on an extent, a map unit and a screen width.
extent RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> This parameter is a world extent.
screenWidth Double<!– System.Double –> This parameter is the width of the map in pixels.
mapUnit GeographyUnit<!– ThinkGeo.MapSuite.Core.GeographyUnit –> This parameter is the unit of the map.
GetZoomLevel(RectangleShape, Double, GeographyUnit, Single)
dpi Single<!– System.Single –> This parameter is the dpi of the extent.
GetZoomLevelForDrawing(RectangleShape, Double, GeographyUnit, Single)
ZoomLevel<!– ThinkGeo.MapSuite.Core.ZoomLevel –> This method returns the active ZoomLevel based on an extent, map unit and a canvas width.
screenWidth Double<!– System.Double –> This parameter is the width of the canvas in pixels.
GetZoomLevelForDrawing(RectangleShape, Double, GeographyUnit)
GetZoomLevels()
Collection<ZoomLevel><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.ZoomLevel} –> This method return all of the zoomlevels in the zoomLevelSet.
String<!– System.String –>
Void<!– System.Void –>
CustomZoomLevels
Return Type
Return Type
ZoomLevel01
Return Type
ZoomLevel02
Return Type
ZoomLevel03
Return Type
ZoomLevel04
Return Type
ZoomLevel05
Return Type
ZoomLevel06
Return Type
ZoomLevel07
Return Type
ZoomLevel08
Return Type
ZoomLevel09
Return Type
ZoomLevel10
Return Type
ZoomLevel11
Return Type
ZoomLevel12
Return Type
ZoomLevel13
Return Type
ZoomLevel14
Return Type
ZoomLevel15
Return Type
ZoomLevel16
Return Type
ZoomLevel17
Return Type
ZoomLevel18
Return Type
ZoomLevel19
Return Type
ZoomLevel20
Return Type
thinkgeo.mapsuite.core.zoomlevelset.1441000860.txt.gz · Last modified: 2015/08/31 06:01 by admin
