thinkgeo.mapsuite.core.yahoomapzoomlevelset
ThinkGeo.MapSuite.Core.YahooMapZoomLevelSet
<!– Class –> This class represents the zoom levels used by Yahoo Maps.
If you want to create some layers that match up with Yahoo Maps layers, you should use this ZoomSet.
Public MethodYahooMapZoomLevelSet This class represents the zoom levels used by Yahoo Maps.
Public MethodStatic MemberGetHigherZoomLevelScale Double, ZoomLevelSet ZoomLevelSet ZoomToScale out, the result is greater than input
Public MethodStatic MemberGetLowerZoomLevelScale Double, ZoomLevelSet ZoomLevelSet ZoomToScale in, the result is less than input
Public MethodGetType Object
Public MethodGetZoomLevel RectangleShape, Double, GeographyUnit ZoomLevelSet This method returns the active ZoomLevel based on an extent, a map unit and a screen width.
Public MethodGetZoomLevel RectangleShape, Double, GeographyUnit, Single ZoomLevelSet This method returns the active ZoomLevel based on an extent, a map unit and a screen width.
Public MethodGetZoomLevelForDrawing RectangleShape, Double, GeographyUnit ZoomLevelSet This method returns the active ZoomLevel based on an extent, a map unit and a canvas width.
Public MethodGetZoomLevelForDrawing RectangleShape, Double, GeographyUnit, Single ZoomLevelSet This method returns the active ZoomLevel based on an extent, a map unit and a canvas width.
Public MethodGetZoomLevels ZoomLevelSet This method return all of the zoomLevels in the zoomLevelSet.
Public MethodToString Object
Public PropertyCustomZoomLevels Collection<ZoomLevel> ZoomLevelSet This property gets the custom zoom levels from the zoomLevelSet.
Public PropertyName String ZoomLevelSet This property gets and sets the name for the ZoomSet.
Public PropertyZoomLevel01 ZoomLevel ZoomLevelSet This property gets the ZoomLevel for Level01.
Public PropertyZoomLevel02 ZoomLevel ZoomLevelSet This property gets the ZoomLevel for Level02.
Public PropertyZoomLevel03 ZoomLevel ZoomLevelSet This property gets the ZoomLevel for Level03.
Public PropertyZoomLevel04 ZoomLevel ZoomLevelSet This property gets the ZoomLevel for Level04.
Public PropertyZoomLevel05 ZoomLevel ZoomLevelSet This property gets the ZoomLevel for Level05.
Public PropertyZoomLevel06 ZoomLevel ZoomLevelSet This property gets the ZoomLevel for Level06.
Public PropertyZoomLevel07 ZoomLevel ZoomLevelSet This property gets the ZoomLevel for Level07.
Public PropertyZoomLevel08 ZoomLevel ZoomLevelSet This property gets the ZoomLevel for Level08.
Public PropertyZoomLevel09 ZoomLevel ZoomLevelSet This property gets the ZoomLevel for Level09.
Public PropertyZoomLevel10 ZoomLevel ZoomLevelSet This property gets the ZoomLevel for Level10.
Public PropertyZoomLevel11 ZoomLevel ZoomLevelSet This property gets the ZoomLevel for Level11.
Public PropertyZoomLevel12 ZoomLevel ZoomLevelSet This property gets the ZoomLevel for Level12.
Public PropertyZoomLevel13 ZoomLevel ZoomLevelSet This property gets the ZoomLevel for Level13.
Public PropertyZoomLevel14 ZoomLevel ZoomLevelSet This property gets the ZoomLevel for Level14.
Public PropertyZoomLevel15 ZoomLevel ZoomLevelSet This property gets the ZoomLevel for Level15.
Public PropertyZoomLevel16 ZoomLevel ZoomLevelSet This property gets the ZoomLevel for Level16.
Public PropertyZoomLevel17 ZoomLevel ZoomLevelSet This property gets the ZoomLevel for Level17.
Public PropertyZoomLevel18 ZoomLevel ZoomLevelSet This property gets the ZoomLevel for Level18.
Public PropertyZoomLevel19 ZoomLevel ZoomLevelSet This property gets the ZoomLevel for Level19.
Public PropertyZoomLevel20 ZoomLevel ZoomLevelSet This property gets the ZoomLevel for Level20.
YahooMapZoomLevelSet()
Name Type Description
Go Back
Return Type Description
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
GetHigherZoomLevelScale(Double, ZoomLevelSet)
<!– static –> ZoomToScale out, the result is greater than input
Double<!– System.Double –>
currentScale Double<!– System.Double –>
zoomLevelSet ZoomLevelSet<!– ThinkGeo.MapSuite.Core.ZoomLevelSet –>
<!– ThinkGeo.MapSuite.Core.ZoomLevelSet –> Go Back
GetLowerZoomLevelScale(Double, ZoomLevelSet)
<!– static –> ZoomToScale in, the result is less than input
Type<!– System.Type –>
GetZoomLevel(RectangleShape, Double, GeographyUnit)
ZoomLevel<!– ThinkGeo.MapSuite.Core.ZoomLevel –> This method returns the active ZoomLevel based on an extent, a map unit and a screen width.
extent RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> This parameter is a world extent.
screenWidth Double<!– System.Double –> This parameter is the width of the map in pixels.
mapUnit GeographyUnit<!– ThinkGeo.MapSuite.Core.GeographyUnit –> This parameter is the unit of the map.
GetZoomLevel(RectangleShape, Double, GeographyUnit, Single)
dpi Single<!– System.Single –> This parameter is the dpi of the extent.
GetZoomLevelForDrawing(RectangleShape, Double, GeographyUnit)
ZoomLevel<!– ThinkGeo.MapSuite.Core.ZoomLevel –> This method returns the active ZoomLevel based on an extent, map unit and a canvas width.
screenWidth Double<!– System.Double –> This parameter is the width of the canvas in pixels.
GetZoomLevelForDrawing(RectangleShape, Double, GeographyUnit, Single)
GetZoomLevels()
Collection<ZoomLevel><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.ZoomLevel} –> This method return all of the zoomlevels in the zoomLevelSet.
String<!– System.String –>
Void<!– System.Void –>
CustomZoomLevels
Return Type
Return Type
ZoomLevel01
Return Type
ZoomLevel02
Return Type
ZoomLevel03
Return Type
ZoomLevel04
Return Type
ZoomLevel05
Return Type
ZoomLevel06
Return Type
ZoomLevel07
Return Type
ZoomLevel08
Return Type
ZoomLevel09
Return Type
ZoomLevel10
Return Type
ZoomLevel11
Return Type
ZoomLevel12
Return Type
ZoomLevel13
Return Type
ZoomLevel14
Return Type
ZoomLevel15
Return Type
ZoomLevel16
Return Type
ZoomLevel17
Return Type
ZoomLevel18
Return Type
ZoomLevel19
Return Type
ZoomLevel20
Return Type
thinkgeo.mapsuite.core.yahoomapzoomlevelset.txt · Last modified: 2017/03/16 21:59 (external edit)
