This class is use for world map kit, and you also can get map from ThinkGeo world map kit server.
The default constructor
The constructor initilizes the properties. UpperThreshold is set to double.MaxValue, LowerThreshold is set to double.MinValue.
layerType
privateKey
clientId
This is the constructor the for the class.
layerType
clientId
This method clears the tile cache.
canvas
labelsInAllLayers
Get the request URLs from the client to the WMS servers.
worldExtent
canvasWidth
canvasHeight
This method returns the projected or geographic coordinate reference systems to be used.
This method returns the exception format at the server side.
None.
This method returns the names of all layers at the server side.
None.
This method returns the output format at the server side.
None.
This method returns the names of all styles at the server side.
None.
This API gets the WMS server version of the service.
extentsToRefresh
bufferTime
bufferTimeType
extentToRefresh
bufferTime
bufferTimeType
bufferTime
bufferTimeType
extentsToRefresh
bufferTime
This method closes the Layer and releases any resources it was using.
This abstract method is called from the concrete public method Close. The close method plays an important role in the life cycle of the Layer. It may be called after drawing to release any memory and other resources that were allocated since the Open method was called. If you override this method, it is recommended that you take the following things into account: This method may be called multiple times, so we suggest you write the method so that that a call to a closed Layer is ignored and does not generate an error. We also suggest that in the Close you free all resources that have been opened. Remember that the object will not be destroyed, but will be re-opened possibly in the near future.
This method draws the Layer.
This method is the concrete wrapper for the abstract method DrawCore. This method draws the representation of the layer based on the extent you provided. When implementing this abstract method, consider each feature and its column data values. You can use the full power of the GeoCanvas to do the drawing. If you need column data for a feature, be sure to override the GetRequiredColumnNamesCore and add the columns you need to the collection. In many of the styles, we add properties that allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore, we read that property and add it to the collection.
canvas
labelsInAllLayers
canvas
e
This method draws image on the canvas with specified labelsInAllLayers
canvas
labelsInAllLayers
This method retures a value represents whether the currentExtent is within the passing in thresholds.
currentExtent
upperThreshold
lowerThreshold
canvasWidth
mapUnit
currentExtent
upperThreshold
lowerThreshold
canvasWidth
mapUnit
dpi
Return Type:String
Return Type:Single
Gets or sets a value that is your Client Id.
Return Type:String
Return Type:DrawingExceptionMode
Return Type:TimeSpan
Return Type:Single
This property indicates whether a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs.
The value of WorldMapKitLayer is false.
Return Type:Boolean
Return Type:Boolean
Return Type:Boolean
Return Type:Boolean
Return Type:Boolean
Return Type:WorldMapKitLayerType
Gets or sets a value represents lower threshold for scale.
Is the current scale is less than this value, the map will not render.
Return Type:Double
Return Type:WorldMapKitMapType
Return Type:String
Gets or sets a value that is unique to your client ID, please keep your key secure.
Return Type:String
Gets or sets a WorldMapKitProjection represents which projection will be use.
Return Type:WorldMapKitProjection
This property gets or sets the proxy used for requesting a Web Response.
Return Type:WebProxy
Return Type:Single
Gets or sets a BitmapTileCache represents which tile cache will be use.
Return Type:BitmapTileCache
Return Type:WorldMapKitTileMode
This property specifies the timeout of the web request in seconds. The default timeout value is 20 seconds.
Return Type:Int32
Return Type:Single
Gets or sets a value represents upper threshold for scale.
Is the current scale is beyond this value, the map will not render.
Return Type:Double
This property returns true if the Layer is open and false if it is not.
Various methods on the Layer require that it be in an open state. If one of those methods is called when the state is not open, then the method will throw an exception. To enter the open state, you must call the Layer Open method. The method will raise an exception if the current Layer is already open.
Return Type:Boolean
Return Type:WorldMapKitWmsRasterSource
Return Type:Collection<String>
Return Type:Dictionary<String,String>
