<!– Class –> This class represents a candidate with world center point information for labeling.
This class is used in the labeling system. We keep track of every potential label in this class as it goes through the labeling rules.
*System.Object ThinkGeo.MapSuite.Core.LabelingCandidate *ThinkGeo.MapSuite.Core.WorldLabelingCandidate
WorldLabelingCandidate | This is a default constructor for the class. | ||
WorldLabelingCandidate | String | This is a constructor for the class. | |
WorldLabelingCandidate | String, PointShape | This is a constructor for the class. |
CenterPoint | PointShape | LabelingCandidate | This property gets and sets the center point for the center of the label. |
CenterPointInWorldCoordinates | PointShape | This property gets or sets the Center Point position in world Coordinate system. | |
LabelInformation | Collection<LabelInformation> | LabelingCandidate | This property gets and sets the label information for this label. |
OriginalText | String | LabelingCandidate | This property gets and sets the original text for the label. |
ScreenArea | PolygonShape | LabelingCandidate | This property gets and sets the screen area that encompasses the label. |
If you use this constructor, then you should set the applicable properties manually.
This constructor allows you to pass in the text of the label.
| originalText | String<!– System.String –> | This parameter represents the text of the label before it is potentially modified. |
This constructor allows you to pass in the text of the label as well as the world center point.
| centerPointInWorldCoordinates | PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> | This parameter is the center of the polygon (in world coordinates) representing the area to be labeled. |
<!– ThinkGeo.MapSuite.Core.LabelingCandidate –> Go Back
<!– ThinkGeo.MapSuite.Core.WorldLabelingCandidate –> Go Back
| Collection<LabelInformation><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.LabelInformation} –> |
| PolygonShape<!– ThinkGeo.MapSuite.Core.PolygonShape –> |
