<!– Class –> This class represents the values of a world file.
A world file is an attribute file that is associated with a corresponding image file. Typically, the world file consists of 6 lines of numbers.
*System.Object **ThinkGeo.MapSuite.Core.WorldFile
![]() | This is the default constructor for the WorldFile class. | ||
![]() | String | This is the constructor that passes the worldFile text. | |
![]() | RectangleShape, Single, Single | This is the constructor that passes the WorldExtent of the image, the height of the image, and the width of the image. | |
![]() | Double, Double, Double, Double, Double, Double | This is a constructor that passes 6 attributes in double associated with the corresponding image file. | |
![]() | Single, Single, Single, Single, Single, Single | This is a constructor that passes 6 attributes in float associated with the corresponding image file. |
![]() | Object | Object | |
![]() | Single, Single | ||
![]() | Object | ||
![]() | Object | ||
![]() | Object |
![]() | Object | ||
![]() | Object |
![]() | Single | This property gets the horizontal resolution from the world file. | |
![]() | Single | This property gets the rotation in column from the world file. | |
![]() | Single | This property gets the rotation in row from the world file. | |
![]() | Single | This property gets the upper left Y coordinate from the world file. | |
![]() | Single | This property gets the upper left X coordinate from the world file. | |
![]() | Single | This property gets the vertical resolution from the world file. |
Name | Type | Description |
The worldFileText is typically read from a world file.
worldFileText | String<!– System.String –> | The world file text containing the world file attribute information. |
worldExtent | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | This parameter specifies the World Coordinate Extent for the image. |
imageWidth | Single<!– System.Single –> | This parameter specifies the image width for the image. |
imageHeight | Single<!– System.Single –> | This parameter specifies the image height for the image. |
horizontalResolution | Double<!– System.Double –> | This parameter specifies the size of pixels in the x direction. |
rotationRow | Double<!– System.Double –> | This parameter specifies the rotation term for row. |
rotationColumn | Double<!– System.Double –> | This parameter specifes the rotation term for column. |
verticalResolution | Double<!– System.Double –> | This parameter specifies the size of pixels in the y direction. |
upperLeftX | Double<!– System.Double –> | This parameter represents the x coordinate of the center of the upper-leftmost pixel in map units. |
upperLeftY | Double<!– System.Double –> | This parameter represents the y coordinate of the center of the upper-leftmost pixel in map units. |
horizontalResolution | Single<!– System.Single –> | This parameter specifies the size of pixels in the x direction. |
rotationRow | Single<!– System.Single –> | This parameter specifies the rotation term for row. |
rotationColumn | Single<!– System.Single –> | This parameter specifes the rotation term for column. |
verticalResolution | Single<!– System.Single –> | This parameter specifies the size of pixels in the y direction. |
upperLeftX | Single<!– System.Single –> | This parameter represents the x coordinate of the center of the upper-leftmost pixel in map units. |
upperLeftY | Single<!– System.Single –> | This parameter represents the y coordinate of the center of the upper-leftmost pixel in map units. |
Return Type | Description |
width | Single<!– System.Single –> | |
height | Single<!– System.Single –> |
<!– ThinkGeo.MapSuite.Core.WorldFile –> Go Back
Int32<!– System.Int32 –> |
Type<!– System.Type –> |
Void<!– System.Void –> |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
