<!– Class –> This class represents the wfs(web feature service) FeauteLayer.
This class allows you to get features from an wfs server.
*System.Object ThinkGeo.MapSuite.Core.Layer *ThinkGeo.MapSuite.Core.FeatureLayer ThinkGeo.MapSuite.Core.WfsFeatureLayer
WfsFeatureLayer | WfsFeatureLayer Constructor. | ||
WfsFeatureLayer | String, String | WfsFeatureSource Constructor |
CloneDeep | Layer | Create a copy of Layer using the deep clone process. | |
Close | Layer | This method closes the Layer and releases any resources it was using. | |
Draw | GeoCanvas, Collection<SimpleCandidate> | Layer | This method draws the Layer. |
GetBoundingBox | Layer | This method returns the bounding box of the Layer. | |
![]() GetCapabilities | String | Get capabilities from the specific wfs service url. | |
![]() GetCapabilities | Uri, WebProxy | Get capabilities from the specific wfs service url. | |
![]() GetCapabilities | Uri | Get capabilities from the specific wfs service url. | |
![]() GetLayers | Uri | Get layer names from specific wfs service url. | |
![]() GetLayers | Uri, WebProxy | Get layer names from specific wfs service url. | |
![]() GetLayers | String | Get layer names from specific wfs service url. | |
![]() LoadLayer | Uri | Layer | |
![]() LoadLayer | Stream | Layer | |
Open | Layer | This method opens the Layer so that it is initialized and ready to use. | |
RequestDrawing | Layer | ||
RequestDrawing | IEnumerable<RectangleShape> | Layer | |
RequestDrawing | IEnumerable<RectangleShape>, TimeSpan, RequestDrawingBufferTimeType | Layer | |
RequestDrawing | TimeSpan | Layer | |
RequestDrawing | TimeSpan, RequestDrawingBufferTimeType | Layer | |
RequestDrawing | RectangleShape, TimeSpan | Layer | |
RequestDrawing | RectangleShape, TimeSpan, RequestDrawingBufferTimeType | Layer | |
RequestDrawing | RectangleShape | Layer | |
RequestDrawing | IEnumerable<RectangleShape>, TimeSpan | Layer | |
DrawingMarginInPixel | Single | FeatureLayer | |
DrawingQuality | DrawingQuality | FeatureLayer | This property gets and sets the general drawing quality for the FeatureLayer's canvas. |
EditTools | EditTools | FeatureLayer | This property gets the EditTools that allow you to easily edit InternalFeatures in the Feature Layer. |
FeatureIdsToExclude | Collection<String> | FeatureLayer | A collection of strings representing record id of features not to get in the Layer. |
FeatureSource | FeatureSource | FeatureLayer | This property gets the FeatureSource for the FeatureLayer. |
GeometryValidationMode | GeometryValidationMode | FeatureLayer | |
HasBoundingBox | Boolean | Layer(overriden) | This property indicates whether a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs. |
LastXmlResponse | String | The xml text represnets last respone, it will pass out by RequestedData event as parameter. | |
MaxRecordsToDraw | Int32 | FeatureLayer | |
QueryTools | QueryTools | FeatureLayer | This property gets the QueryTools that allow you to easily query Features from the Feature Layer. |
ServiceLocationUrl | String | The url of wfs service. | |
TimeoutInSeconds | Int32 | This property specifies the timeout of the web request in seconds. The default timeout value is 20 seconds. | |
TypeName | String | The typename in the specify wfs service. | |
WebProxy | WebProxy | This property gets or sets the proxy used for requesting a Web Response. | |
WrappingExtent | RectangleShape | FeatureLayer | |
WrappingMode | WrappingMode | FeatureLayer | Thie property gets or sets whether allow wrap date line. |
ZoomLevelSet | ZoomLevelSet | FeatureLayer | This property gets and sets the ZoomLevelSet, which contains the specific zoom levels for the FeatureLayer. |
IsOpenCore | Boolean | Layer(overriden) |
DrawingAttribution | DrawingAttributionLayerEventArgs | Layer | |
DrawingException | DrawingExceptionLayerEventArgs | Layer | |
DrawingFeatures | DrawingFeaturesEventArgs | FeatureLayer | This event is raised when features are about to be drawn in the layer. |
DrawingProgressChanged | DrawingProgressChangedEventArgs | Layer | |
DrawingWrappingFeatures | DrawingWrappingFeaturesFeatureLayerEventArgs | FeatureLayer | |
DrawnAttribution | DrawnAttributionLayerEventArgs | Layer | |
DrawnException | DrawnExceptionLayerEventArgs | Layer | |
RequestedDrawing | RequestedDrawingLayerEventArgs | Layer | |
RequestingDrawing | RequestingDrawingLayerEventArgs | Layer | |
SendingWebRequest | SendingWebRequestEventArgs | ||
SentWebRequest | SentWebRequestEventArgs |
The parameters can not be null.
| serviceLocationUrl | String<!– System.String –> | The url of wfs service. |
| typeName | String<!– System.String –> | The typename in the specify wfs service. |
<!– static –> Get capabilities from the specific wfs service url.
Every OGC Web Service (OWS), including a Web Feature Service, must have the ability to describe its capabilities by returning service metadata in response to a GetCapabilities request. Specifically, every web feature service must support the KVP encoded form of the GetCapabilities request over HTTP GET so that a client can always know how to obtain a capabilities document.
The capabilities response document contains the following sections: 1. Service Identification section The service identification section provides information about the WFS service itself. 2. Service Provider section The service provider section provides metadata about the organization operating the WFS server. 3. Operation Metadata section The operations metadata section provides metadata about the operations defined in this specification and implemented by a particular WFS server. This metadata includes the DCP, parameters and constraints for each operation. 4. FeatureType list section This section defines the list of feature types (and operations on each feature type) that are available from a web feature service. Additional information, such as the default SRS, any other supported SRSs, or no SRS whatsoever (for non-spatial feature types), for WFS requests is provided for each feature type. 5. ServesGMLObjectType list section This section defines the list of GML Object types, not derived from gml:AbstractFeatureType, that are available from a web feature service that supports the GetGMLObject operation. These types may be defined in a base GML schema, or in an application schema using its own namespace. 6. SupportsGMLObjectType list section The Supports GML Object Type section defines the list of GML Object types that a WFS server would be capable of serving if it was deployed to serve data. described by an application schema that either used those GML Object types directly (for non-abstract types), or defined derived types based on those types. 7. Filter capabilities section The schema of the Filter Capabilities Section is defined in the Filter Encoding Implementation Specification 3. This is an optional section. If it exists, then the WFS should support the operations advertised therein. If the Filter Capabilities Section is not defined, then the client should assume that the server only supports the minimum default set of filter operators.
| String<!– System.String –> | The xml text represents capabilities of this wfs server. |
<!– ThinkGeo.MapSuite.Core.WfsFeatureLayer –> Go Back
| serverUri | Uri<!– System.Uri –> | The url of wfs service. |
| webProxy | WebProxy<!– System.Net.WebProxy –> | The proxy of the wfs service. |
<!– static –> Get layer names from specific wfs service url.
| Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –> | The collection represent layer names. |
Typically, it will call WfsFeatureSource.GetLayers(serverUri) internally.
Typically, it will call WfsFeatureSource.GetLayers(serviceLocationUrl) internally.
<!– static –>
<!– static –>
| extentsToRefresh | IEnumerable<RectangleShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.RectangleShape} –> |
Create a copy of Layer using the deep clone process. The default implemenation uses serialization.
This method raises the DrawingFeatures event.
<list type=“bullet”> <item>You can call this method from a derived class to enable it to raise the event. This may be useful if you plan to extend the FeatureLayer and you need access to the event.
This event is meant to allow you to add or remove the features to be drawn.</item> </list>
| e | DrawingFeaturesEventArgs<!– ThinkGeo.MapSuite.Core.DrawingFeaturesEventArgs –> | This parameter represents the event arguments for the event. |
<!– ThinkGeo.MapSuite.Core.FeatureLayer –> Go Back
| e | DrawingWrappingFeaturesFeatureLayerEventArgs<!– ThinkGeo.MapSuite.Core.DrawingWrappingFeaturesFeatureLayerEventArgs –> |
This method sets up the EditTools and QueryTools objects.
This method is the concrete wrapper for the abstract method SetupToolsCore. The SetupTools method allows you to create the QueryTool, EditTools and other tools you may need on your object. We created this method so that if you want to extend one of the tool classes, you can override the SetupToolsCore and create any class you want.
This method is the concrete wrapper for the abstract method SetupTools. The SetupTools method allows you to create the QueryTool, EditTools and other tools you may need on your object. We created this method so that if you want to extend one of the tool classes, you can override the SetupToolsCore and create any class you want.
The DrawingQuality enumeration allows you to control, in a macro sense, the drawing quality that will be used in the GeoCanvas. Each GeoCanvas, which is responsible for drawing of the features, may have its own specialized drawing quality properties. What the DrawingQuality enumeration does is define some general guidelines for each GeoCanvas. For example, if you set the DrawingQuality to HighSpeed, then inside of the GdiPlusGeoCanvas there is a profile for HighSpeed. This profile sets specific properties, such as the smoothing mode and composing drawing mode of the GdiPlusGeoCanvas. As each GeoCanvas may have different drawing quality properties, this offers a general way to control drawing quality and speed.
If you need complete control over how a specific GeoCanvas will draw, then you can set the DrawingQuality to Custom. This will tell the specific GeoCanvas to use the properties on its own object instead of one of the pre-defined profiles. If one of the profiles – such as HighSpeed or HighQuality – is set, then the specific GeoCanvas ignores its own properties for drawing quality.
| DrawingQuality<!– ThinkGeo.MapSuite.Core.DrawingQuality –> |
The EditTools are supplied as an easily accessible wrapper for the editing methods of the FeatureSource.
| EditTools<!– ThinkGeo.MapSuite.Core.EditTools –> |
The FeatureSource is the provider of data to the FeatureLayer. There are different FeatureSource classes to match the various ways that feature data is stored. It is important that, when you inherit from the FeatureLayer, in the constructor you set the FeatureSource you want to use.
| FeatureSource<!– ThinkGeo.MapSuite.Core.FeatureSource –> |
| GeometryValidationMode<!– ThinkGeo.MapSuite.Core.GeometryValidationMode –> |
The default value is false.
This property gets the QueryTools that allow you to easily query Features from the Feature Layer. The QueryTools are supplied as an easily accessible wrapper for the query methods of the FeatureSource.
| QueryTools<!– ThinkGeo.MapSuite.Core.QueryTools –> |
| WrappingMode<!– ThinkGeo.MapSuite.Core.WrappingMode –> |
The ZoomLevelSet is a class that contains all of the ZoomLevels for the FeatureLayer. Each ZoomLevel contains the styles that are used to determine how to draw the InternalFeatures.
| ZoomLevelSet<!– ThinkGeo.MapSuite.Core.ZoomLevelSet –> |
| Event Arguments |
| Event Arguments |
This event is raised when features are about to be drawn in the layer. In the event arguments, there is a collection of features to be drawn. You can easily add or remove items from this collection so that extra items will draw or not draw.
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| SendingWebRequestEventArgs<!– ThinkGeo.MapSuite.Core.SendingWebRequestEventArgs –> |
| Event Arguments |
| SentWebRequestEventArgs<!– ThinkGeo.MapSuite.Core.SentWebRequestEventArgs –> |
