thinkgeo.mapsuite.core.transactionresult
ThinkGeo.MapSuite.Core.TransactionResult
    • ThinkGeo.MapSuite.Core.TransactionResult
TransactionResult
  • Parameters:N/A
  • DeclaringType:N/A
  • Summary:This is the class constructor.
TransactionResult
Equals
  • Parameters:Object
  • DeclaringType:Object
  • Summary:N/A
GetHashCode
  • Parameters:N/A
  • Summary:N/A
GetType
  • Parameters:N/A
  • Summary:N/A
ToString
  • Parameters:N/A
  • Summary:N/A
Finalize
  • Parameters:N/A
  • Summary:N/A
MemberwiseClone
  • Parameters:N/A
  • Summary:N/A
FailureReasons
  • Return:Dictionary<String,String>
  • Summary:This property gets and sets the dictionary that contains the reasons for failure.
TotalFailureCount
  • Return:Int32
  • Summary:This property gets and sets the total number of records that we committed unsuccessfully.
TotalSuccessCount
  • Return:Int32
  • Summary:This property gets and sets the total number of records that we committed successfully.
TransactionResultStatus
TransactionResult()
This is the default constructor and is typically not used.
TransactionResult(Int32,Int32,Dictionary<String,String>,TransactionResultStatus)
totalSuccessCount
  • Description:N/A totalFailureCount * Type:Int32 * Description:N/A
failureReasons
  • Description:N/A transactionResultStatus * Type:TransactionResultStatus * Description:N/A
Go Back
  • Return Type:Boolean
obj
Go Back
  • Return Type:Int32
  • Return Type:Type
  • Return Type:String
  • Return Type:Void
  • Return Type:Object
FailureReasons
If there are failing records we suggest you add the failure reasons to this dictionary. It is also suggested that you use the FeatureId as the key of the Dictionary.
Return Type:Dictionary<String,String>
Go Back
TotalFailureCount
Return Type:Int32
Go Back
TotalSuccessCount
Return Type:Int32
Go Back
This property gets and sets the result status of the transaction.
This property returns the results of the transaction. If all of the records committed fine then you get a success status. If any of the records fail then you get a failure status though some of the records may have committed.
thinkgeo.mapsuite.core.transactionresult.1442486493.txt.gz · Last modified: 2015/09/17 10:41 by admin
