thinkgeo.mapsuite.core.tilematrixcell
ThinkGeo.MapSuite.Core.TileMatrixCell
    • System.ValueType
      • ThinkGeo.MapSuite.Core.TileMatrixCell
TileMatrixCell
  • Parameters:Int64,Int64,RectangleShape
  • DeclaringType:N/A
  • Summary:This is the constructor used to create a TileMatrixCell.
Equals
  • Parameters:Object
  • DeclaringType:N/A
  • Summary:This method is an override of the Equals functionality.
GetHashCode
  • Parameters:N/A
  • DeclaringType:N/A
  • Summary:This method is an override of the GetHashCode functionality.
GetType
  • Parameters:N/A
  • DeclaringType:Object
  • Summary:N/A
ToString
  • Parameters:N/A
  • DeclaringType:N/A
  • Summary:This method is an override of the ToString functionality.
Finalize
  • Parameters:N/A
  • Summary:N/A
MemberwiseClone
  • Parameters:N/A
  • Summary:N/A
BoundingBox
  • Summary:This property gets or sets the BoundingBox of the stucture.
Column
  • Return:Int64
  • Summary:This property gets or sets the Column number of the stucture.
Row
  • Return:Int64
  • Summary:This property gets or sets the Row number of the stucture.
TileMatrixCell(Int64,Int64,RectangleShape)
row
  • Type:Int64
  • Description:This parameter represents the row number of the TileMatrixCell. column * Type:Int64 * Description:This parameter represents the column number of the TileMatrixCell.
boundingBox
  • Description:This parameter represents the boundingBox of the TileMatrixCell. Go Back ===== Protected Constructors ===== ===== Public Methods ===== === Equals(Object) === This method is an override of the Equals functionality. ==== Remarks ==== None Return Value * Return Type:Boolean * Description:N/A ==== Parameters ==== obj * Type:Object * Description:N/A Go Back === GetHashCode() === This method is an override of the GetHashCode functionality. ==== Remarks ==== None Return Value * Return Type:Int32 * Description:N/A ==== Parameters ==== Go Back === GetType() === N/A ==== Remarks ==== N/A Return Value * Return Type:Type * Description:N/A ==== Parameters ==== Go Back === ToString() === This method is an override of the ToString functionality. ==== Remarks ==== None Return Value * Return Type:String * Description:N/A ==== Parameters ==== Go Back ===== Protected Methods ===== === Finalize() === N/A ==== Remarks ==== N/A Return Value * Return Type:Void * Description:N/A ==== Parameters ==== Go Back === MemberwiseClone() === N/A ==== Remarks ==== N/A Return Value * Return Type:Object * Description:N/A ==== Parameters ==== Go Back ===== Public Properties ===== === BoundingBox === This property gets or sets the BoundingBox of the stucture. ==== Remarks ==== N/A ==== Return Value ==== Return Type:RectangleShape Go Back === Column === This property gets or sets the Column number of the stucture. ==== Remarks ==== N/A ==== Return Value ==== Return Type:Int64 Go Back === Row === This property gets or sets the Row number of the stucture. ==== Remarks ==== N/A ==== Return Value ==== Return Type**:Int64
Go Back
thinkgeo.mapsuite.core.tilematrixcell.1442486470.txt.gz · Last modified: 2015/09/17 10:41 by admin
