thinkgeo.mapsuite.core.tilematrixcell
ThinkGeo.MapSuite.Core.TileMatrixCell
<!– Structure –> This structure represents the TileMatrixCell which will be used in the TileMatrix system.
Public MethodTileMatrixCell Int64, Int64, RectangleShape This is the constructor used to create a TileMatrixCell.
Public MethodEquals Object Object(overriden) This method is an override of the Equals functionality.
Public MethodGetHashCode Object(overriden) This method is an override of the GetHashCode functionality.
Public MethodGetType Object
Public MethodToString Object(overriden) This method is an override of the ToString functionality.
Public PropertyBoundingBox RectangleShape This property gets or sets the BoundingBox of the stucture.
Public PropertyColumn Int64 This property gets or sets the Column number of the stucture.
Public PropertyRow Int64 This property gets or sets the Row number of the stucture.
TileMatrixCell(Int64, Int64, RectangleShape)
Name Type Description
row Int64<!– System.Int64 –> This parameter represents the row number of the TileMatrixCell.
column Int64<!– System.Int64 –> This parameter represents the column number of the TileMatrixCell.
boundingBox RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> This parameter represents the boundingBox of the TileMatrixCell.
Go Back
Return Type Description
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
String<!– System.String –>
Void<!– System.Void –>
BoundingBox
Return Type
<!– ThinkGeo.MapSuite.Core.TileMatrixCell –> Go Back
Column
Return Type
Row
Return Type
thinkgeo.mapsuite.core.tilematrixcell.1440040130.txt.gz · Last modified: 2015/09/17 10:41 (external edit)
