<!– Class –> The event args containing the event data used by SecuredTiledWmsRasterSource.
*System.Object System.EventArgs *ThinkGeo.MapSuite.Core.SentRequestWmsRasterSourceEventArgs
SentRequestWmsRasterSourceEventArgs | HttpWebResponse | Create an instance of SentRequestWmsRasterSourceEventArgs |
Response | HttpWebResponse | Gets or sets a value indicating the response from Server. |
| response | HttpWebResponse<!– System.Net.HttpWebResponse –> |
<!– ThinkGeo.MapSuite.Core.SentRequestWmsRasterSourceEventArgs –> Go Back
