<!– Class –>
*System.Object System.EventArgs *ThinkGeo.MapSuite.Core.SentRequestBingMapsLayerEventArgs
SentRequestBingMapsLayerEventArgs | |||
SentRequestBingMapsLayerEventArgs | HttpWebResponse | Create an instance of SentRequestBingMapsLayerEventArgs |
Response | HttpWebResponse | Gets or sets a value indicating the response from Server. |
| response | HttpWebResponse<!– System.Net.HttpWebResponse –> |
<!– ThinkGeo.MapSuite.Core.SentRequestBingMapsLayerEventArgs –> Go Back
