thinkgeo.mapsuite.core.sendingrequestbingmapslayereventargs
ThinkGeo.MapSuite.Core.SendingRequestBingMapsLayerEventArgs
<!– Class –>
Public MethodSendingRequestBingMapsLayerEventArgs
Public MethodSendingRequestBingMapsLayerEventArgs WebRequest Create an instance of SendingRequestBingMapsLayerEventArgs
Public MethodGetType Object
Public MethodToString Object
Public PropertyWebRequest WebRequest Gets or sets the request object
SendingRequestBingMapsLayerEventArgs()
Name Type Description
Go Back
SendingRequestBingMapsLayerEventArgs(WebRequest)
webRequest WebRequest<!– System.Net.WebRequest –>
Go Back
Return Type Description
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
String<!– System.String –>
Void<!– System.Void –>
WebRequest
Return Type
<!– ThinkGeo.MapSuite.Core.SendingRequestBingMapsLayerEventArgs –> Go Back
thinkgeo.mapsuite.core.sendingrequestbingmapslayereventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
