<!– Class –>
*System.Object ThinkGeo.MapSuite.Core.Layer *ThinkGeo.MapSuite.Core.PrinterLayer ThinkGeo.MapSuite.Core.ScaleBarPrinterLayer
ScaleBarPrinterLayer | MapPrinterLayer | Creates a new instance of the ScaleBarAdornmentLayer class. |
CloseCore | Layer | This method closes the Layer and releases any resources it was using. | |
DrawCore | GeoCanvas, Collection<SimpleCandidate> | Layer(overriden) | This method draws the Layer. |
DrawExceptionCore | GeoCanvas, Exception | Layer | This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException. |
GetBoundingBoxCore | Layer(overriden) | ||
GetPositionCore | PrintingUnit | PrinterLayer | |
MemberwiseClone | Object | ||
OpenCore | Layer | This method opens the Layer so that it is initialized and ready to use. | |
SetPositionCore | Double, Double, Double, Double, PrintingUnit | PrinterLayer |
AlternateBarBrush | GeoBrush | The property is the GeoBrush that will be used to draw the alternate ScaleBar. | |
BackgroundMask | AreaStyle | PrinterLayer | |
BarBrush | GeoBrush | The property is the GeoBrush that will be used to draw the ScaleBar. | |
DisplayUnitString | Dictionary<String,String> | This propery is a dictionary that exposes what text will be drawn to represent the ScaleLine Unit. | |
DragMode | PrinterDragMode | PrinterLayer | |
GridPen | GeoPen | ||
HasBoundingBox | Boolean | Layer(overriden) | |
HasMask | Boolean | Gets or sets whether the ScaleBar will have a mask or not. A boolean value representing whether or not a mask is shown. | |
Height | Int32 | Gets or sets the thickness of the ScaleBar. It is an integer value representing the height of the ScaleBar in screen units. | |
IsDrawing | Boolean | PrinterLayer | |
MapPrinterLayer | MapPrinterLayer | ||
MapUnit | GeographyUnit | ||
MaskBrush | GeoBrush | Gets or sets the color for the ScaleBarAdornmentLayer's mask, if the HasMask property is set to true. | |
MaskOuterPen | GeoPen | Gets or sets the pen for the outline of the ScaleBar mask. | |
MaxWidth | Int32 | Gets or Sets the MaxWidth of the ScaleBar. | |
ResizeMode | PrinterResizeMode | PrinterLayer | |
SelectabilityMode | SelectabilityMode | PrinterLayer | |
TextStyle | TextStyle | ||
UnitFamily | UnitSystem | Gets or sets the UnitSystem (Imperial/Metric) to be used for the ScaleBar. |
IsOpenCore | Boolean | Layer | This property returns true if the Layer is open and false if it is not. |
The ScaleBar will not be drawn when the <strong>CurrentExtent</strong> is outside of the world Extent(-90,180-,90,-180).
| mapPrinterLayer | MapPrinterLayer<!– ThinkGeo.MapSuite.Core.MapPrinterLayer –> |
This method returns the bounding box of the Layer.
| unit | PrintingUnit<!– ThinkGeo.MapSuite.Core.PrintingUnit –> |
<!– ThinkGeo.MapSuite.Core.PrinterLayer –> Go Back
<!– static –>
<!– static –>
| extentToRefresh | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> |
| width | Double<!– System.Double –> | |
| height | Double<!– System.Double –> | |
| centerPointX | Double<!– System.Double –> | |
| centerPointY | Double<!– System.Double –> | |
| corner | LayerAnchorLocation<!– ThinkGeo.MapSuite.Core.LayerAnchorLocation –> | |
| cornerPoint | PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> | |
| cornerPointX | Double<!– System.Double –> | |
| cornerPointY | Double<!– System.Double –> | |
| boundingBox | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> |
| boundingBox | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | |
| centerPoint | PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> | |
This abstract method is called from the concrete public method Draw. This method draws the representation of the layer based on the extent you provided.
When implementing this abstract method, consider each feature and its column data values. You can use the full power of the GeoCanvas to do the drawing. If you need column data for a feature, be sure to override the GetRequiredColumnNamesCore and add the columns you need to the collection. In many of the styles, we add properties to allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore, we read that property and add it to the collection.
This abstract method is called from the concrete public method Open. The open method plays an important role, as it is responsible for initializing the Layer. Most methods on the Layer will throw an exception if the state of the Layer is not opened. When the map draws each layer, the layer will be opened as one of its first steps; then, after it is finished drawing with that layer, it will close it. In this way, we are sure to release all resources used by the Layer.
This <strong>AlternateBarBrush</strong> property will give you full control over the appearance of the <strong>ScaleBarAdornmentLayer</strong>.
| GeoBrush<!– ThinkGeo.MapSuite.Core.GeoBrush –> |
<!– ThinkGeo.MapSuite.Core.ScaleBarPrinterLayer –> Go Back
| AreaStyle<!– ThinkGeo.MapSuite.Core.AreaStyle –> |
This <strong>BarBrush</strong> property will give you full control over the appearance of the <strong>ScaleBarAdornmentLayer</strong>.
We will display different letters for different units of measure; for example: “m” for meters, “ft” for feet, etc.
| Dictionary<String,String><!– System.Collections.Generic.Dictionary{System.String,System.String} –> |
| PrinterDragMode<!– ThinkGeo.MapSuite.Core.PrinterDragMode –> |
| GeoPen<!– ThinkGeo.MapSuite.Core.GeoPen –> |
Depending upon the look of your map and your requirements, you may or may not want a mask on the ScaleBar. You can control whether or not the ScaleBar has a mask by setting this property. If you set the <strong>HasMask</strong> property to true, be sure to specify a mask color (or texture) by using the <strong>MaskBrush</strong> property.
By using this property you can control the border of the mask, if the <strong>HasMask</strong> property is set to true. If you do not want a contour or border to show, you should set the pen to transparent.
You can use this property to set the maximum width that you want the ScaleBar to occupy on the map. The <strong>ScaleBarAdornmentLayer</strong> will automatically adjust its size based upon the current extent of the map. By setting this property, you can control the maximum width the ScaleBar will occupy on the map.
| PrinterResizeMode<!– ThinkGeo.MapSuite.Core.PrinterResizeMode –> |
| SelectabilityMode<!– ThinkGeo.MapSuite.Core.SelectabilityMode –> |
| TextStyle<!– ThinkGeo.MapSuite.Core.TextStyle –> |
By setting this property, you can control whether to use a metric or imperial measurement system for the ScaleBar.
| UnitSystem<!– ThinkGeo.MapSuite.Core.UnitSystem –> |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
