thinkgeo.mapsuite.core.rowcolumnrange
ThinkGeo.MapSuite.Core.RowColumnRange
    • System.ValueType
      • ThinkGeo.MapSuite.Core.RowColumnRange
RowColumnRange(Int64,Int64,Int64,Int64)
Contructor of the structure to instance a RowColumnRange.
  • minRowIndex
    • Type:Int64
    • Description:Min Row Index which stands for the up boundary.
  • maxRowIndex
    • Type:Int64
    • Description:Max Row Index which stands for the lower boundary.
  • minColumnIndex
    • Type:Int64
    • Description:Min Column Index which stands for the left boundary.
  • maxColumnIndex
    • Type:Int64
    • Description:Max Column Index which stands for the right boundary.
This method is an override of the GetHashCode functionality.
This method is an override of the Equals functionality.
MinRowIndex
Gets or sets the Min Row Index which stands for the up boundary.
  • Type:Int64
MaxRowIndex
Gets or sets the Max Row Index which stands for the lower boundary.
  • Type:Int64
MinColumnIndex
Gets or sets the Min Column Index which stands for the left boundary.
  • Type:Int64
MaxColumnIndex
Gets or sets the Max Column Index which stands for the right boundary.
  • Type:Int64
thinkgeo.mapsuite.core.rowcolumnrange.1442555449.txt.gz · Last modified: 2015/09/18 05:50 by admin
