<!– Structure –> This structure is used to describe a range of tiles for a given extent. Basiclly, 4 values exists : the Row range is from MinColumnIndex to MaxColumnIndex, the Column range is from the MinRowIndex to MaxRowIndex.
*System.ValueType **ThinkGeo.MapSuite.Core.RowColumnRange
RowColumnRange | Int64, Int64, Int64, Int64 | Contructor of the structure to instance a RowColumnRange. |
Equals | Object | Object(overriden) | This method is an override of the Equals functionality. |
GetHashCode | Object(overriden) | This method is an override of the GetHashCode functionality. | |
ToString | Object(overriden) |
MaxColumnIndex | Int64 | Gets or sets the Max Column Index which stands for the right boundary. | |
MaxRowIndex | Int64 | Gets or sets the Max Row Index which stands for the lower boundary. | |
MinColumnIndex | Int64 | Gets or sets the Min Column Index which stands for the left boundary. | |
MinRowIndex | Int64 | Gets or sets the Min Row Index which stands for the up boundary. |
| minRowIndex | Int64<!– System.Int64 –> | Min Row Index which stands for the up boundary. |
| maxRowIndex | Int64<!– System.Int64 –> | Max Row Index which stands for the lower boundary. |
| minColumnIndex | Int64<!– System.Int64 –> | Min Column Index which stands for the left boundary. |
| maxColumnIndex | Int64<!– System.Int64 –> | Max Column Index which stands for the right boundary. |
<!– ThinkGeo.MapSuite.Core.RowColumnRange –> Go Back
