<!– Class –> This layer can show or hide one or many zones that you want to restrict from being displayed. You can use the specified style to decorate the zones and set the lower/upper scale to control at which zoom levels you want to show or hide the zones. The default decoration style is a hatch pattern. You can change this to a circle with slash image, or, if you want a different look, you can use custom styles.
*System.Object ThinkGeo.MapSuite.Core.Layer *ThinkGeo.MapSuite.Core.RestrictionLayer
RestrictionLayer | Initializes a new instance of the RestictionLayer class. | ||
RestrictionLayer | IEnumerable<AreaBaseShape> | Initializes a new instance of the RestictionLayer class for the specified zones. | |
RestrictionLayer | IEnumerable<AreaBaseShape>, RestrictionMode | Initializes a new instance of the RestictionLayer class for the specified zones and restriction mode. | |
RestrictionLayer | IEnumerable<AreaBaseShape>, RestrictionMode, Double, Double | Initializes a new instance of the RestictionLayer class for the specified zones, restriction mode, upper scale and lower scale. |
CloneDeep | Layer | Create a copy of Layer using the deep clone process. | |
Close | Layer | This method closes the Layer and releases any resources it was using. | |
Draw | GeoCanvas, Collection<SimpleCandidate> | Layer | This method draws the Layer. |
GetBoundingBox | Layer | This method returns the bounding box of the Layer. | |
![]() LoadLayer | Stream | Layer | |
![]() LoadLayer | Uri | Layer | |
Open | Layer | This method opens the Layer so that it is initialized and ready to use. | |
RequestDrawing | TimeSpan, RequestDrawingBufferTimeType | Layer | |
RequestDrawing | IEnumerable<RectangleShape> | Layer | |
RequestDrawing | RectangleShape, TimeSpan | Layer | |
RequestDrawing | RectangleShape, TimeSpan, RequestDrawingBufferTimeType | Layer | |
RequestDrawing | IEnumerable<RectangleShape>, TimeSpan | Layer | |
RequestDrawing | RectangleShape | Layer | |
RequestDrawing | Layer | ||
RequestDrawing | IEnumerable<RectangleShape>, TimeSpan, RequestDrawingBufferTimeType | Layer | |
RequestDrawing | TimeSpan | Layer | |
CloseCore | Layer | This method closes the Layer and releases any resources it was using. | |
DrawCore | GeoCanvas, Collection<SimpleCandidate> | Layer(overriden) | This method draws the Layer. |
DrawExceptionCore | GeoCanvas, Exception | Layer | This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException. |
GetBoundingBoxCore | Layer(overriden) | This method returns the bounding box of the zones. | |
MemberwiseClone | Object | ||
OpenCore | Layer | This method opens the Layer so that it is initialized and ready to use. |
CustomStyles | GeoCollection<Style> | Allows you to add custom styles to decorate restriction zones. In this case, you must set RestrictionStyle to UseCustomStyles as well. | |
HasBoundingBox | Boolean | Layer | This property indicates whether a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs. |
LowerScale | Double | Specifies the lower threshold of the layer. | |
RestrictionMode | RestrictionMode | Specifies whether you want to show or hide zones. | |
RestrictionStyle | RestrictionStyle | Specifies the display style of the restriction zones. | |
UpperScale | Double | Specifies the upper threshold of the layer. | |
Zones | GeoCollection<AreaBaseShape> | Specifies the areas you want to restrict. |
IsOpenCore | Boolean | Layer | This property returns true if the Layer is open and false if it is not. |
| zones | IEnumerable<AreaBaseShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.AreaBaseShape} –> |
| zones | IEnumerable<AreaBaseShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.AreaBaseShape} –> | |
| zonesToShowOrHide | RestrictionMode<!– ThinkGeo.MapSuite.Core.RestrictionMode –> |
| zonesToShowOrHide | RestrictionMode<!– ThinkGeo.MapSuite.Core.RestrictionMode –> | |
| upperScale | Double<!– System.Double –> | |
| lowerScale | Double<!– System.Double –> |
<!– static –>
<!– static –>
| extentsToRefresh | IEnumerable<RectangleShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.RectangleShape} –> |
This abstract method is called from the concrete public method Draw. This method draws the representation of the layer based on the extent you provided.
When implementing this abstract method, consider each feature and its column data values. You can use the full power of the GeoCanvas to do the drawing. If you need column data for a feature, be sure to override the GetRequiredColumnNamesCore and add the columns you need to the collection. In many of the styles, we add properties to allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore, we read that property and add it to the collection.
| RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | This method returns the bounding box of the zones. |
This abstract method is called from the concrete public method Open. The open method plays an important role, as it is responsible for initializing the Layer. Most methods on the Layer will throw an exception if the state of the Layer is not opened. When the map draws each layer, the layer will be opened as one of its first steps; then, after it is finished drawing with that layer, it will close it. In this way, we are sure to release all resources used by the Layer.
| GeoCollection<Style><!– ThinkGeo.MapSuite.Core.GeoCollection{ThinkGeo.MapSuite.Core.Style} –> |
<!– ThinkGeo.MapSuite.Core.RestrictionLayer –> Go Back
The default value is false.
If Restriction mode is ShowZones:
If currentScale is less than <strong>LowerScale</strong>, it will hide the whole map; otherwise, it will show the specified zones.
If Restriction mode is HideZones:
if currentScale is less than or equal to UpperScale and greater than or equal to <strong>LowerScale</strong>, it will hide the specified zones; otherwise it will do nothing.
| RestrictionStyle<!– ThinkGeo.MapSuite.Core.RestrictionStyle –> |
<strong>If Restriction mode is ShowZones:</strong>
If currentScale is greater than <strong>UpperScale</strong>, it will hide the whole map; otherwise, it will show the specified zones.
<strong>If Restriction mode is HideZones:</strong>
If currentScale is less than or equal to <strong>UpperScale</strong> and greater than or equal to LowerScale, it will hide the specified zones; otherwise, it will do nothing.
| GeoCollection<AreaBaseShape><!– ThinkGeo.MapSuite.Core.GeoCollection{ThinkGeo.MapSuite.Core.AreaBaseShape} –> |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
